Results 1 to 15 of 15
Thread: Battery issue
10-11-2011, 02:25 PM #1GET SOME
- Apr 2007
- San Antonio, Texas
Pewter Metallic- 2002 Pontiac Trans AM
Battery issue
New alternator, new red cap optima, new starter..at an idle the charging gauge indicates like 9 volts and as the rpm's increase the meter goes to about 13 when it should run at 13-14..I dont have many electronics on the car besides a single 12, a double din, and HID's in the heads and fogs..Its just very agrivating becuase at 9 volts the fogs begin to flicker..im thinking there is a short somewhere when the accessories turn on and have tried to track it with no success..any advice to find the source?? and advice or help is greatly appreciated.!
10-13-2011, 11:24 PM #2Electrical Engineer
- Jul 2009
- North of the Motorcity
Try shutting of each aftermarket device to see if the voltage picks up.
New alt or new re-manufactured alt?
Lastly, the optima is a waste of money.
10-14-2011, 03:04 AM #3
Go back over your connections and check for any corrosion or possible breakage. How are you checking your voltage, with the dash gauge or a DVOM? If you increase the rpm, does the voltage also increase? Unfortunately, new parts do not always work -- been there done that too many times with junk parts and it is frustrating.
10-14-2011, 08:38 AM #4
like people have said check all of your connections again.... i have personally seen brand new and reman alts. being bad straight out of the box it is uncommon but iv seen it... about optimas they are not completely a waste of money but i got mine for dirt cheap and know many people who have them also... being a red top it is a must that you get your voltage problem fixed draining a red top to much will kill it in no time, only the yellow and blue top optimas can handle being drained... also take a volt meter to your battery terminals to make sure your volt gauge(in your car) is reading correctly.
10-18-2011, 11:30 AM #5GET SOME
- Apr 2007
Remanufactured alternator, lifetime warranty! Yes im going just by the voltage meter in the vehicle, due to the fact that when it goes low components start to get weak such as the lights, radio etc. so I know its pretty accurate.. also the voltage does increase as the rpm's increase and runs about 14volts at 1500 rpm..but at a 900 rpm idle it has been substantially low...ive pulled fuses and all aftermarket accessories and have not seen a chane in the voltage but will work on it further this weekend..what I did notice though and dont bash the inexperienced but I do have an underdrive pulley kit on the car..and when I flip the a/c switch is when the car lugs down like 3 whole volts..i never noticed it because usually the a/c stays on at all times even if it is low but with it off it charges perfect..they were on the car when i bought it, and have read nothing but good reviews regarding the charging system..im thinking they could barely be keeping up with the alternator and when I flip the a/c on it overloads system and pulls the alternator down..correct?
10-18-2011, 12:33 PM #6
your A/C will draw more power due to the extra load on the car but it should easily regain its power within a second... do you ever have to jump your car? a normal alt. should put out 13.5-15.5 in perfect working condition like you stated in your first post but if you never have to jump it then the alt is obviously doing something... im do not know much about underdrive pulleys but you may need to put an overdrive pulley on your alt. to regain speed for your charging system?
10-18-2011, 04:56 PM #7Junior Member
- May 2009
- Santa Maria, California
Black- 1998 Pontiac Formula LS6
Two months ago I got my car back on the road after installing an LS6. I left the AC parts off since I had a warped/ clogged AC condenser. I installed an ASP pulley on my car and I was concerned about a charging problem. It's a non problem for me. My Optima red top seems to be charging fine +13VDC (at idle). I'm still using my original alt. from my LS1 and I now have 129K on my car with 4K on the new engine. My original wet cell battery broke at the terminal and acid ate up some of the paint under the hood in the area around the antii-sway bar. I fixed the problem with POR-15 and an Optima red top. I'll swear by Optima batteries for that fact alone.
You might have an alt. issue. Find out what rpm you have acceptable voltage charging your battery. It should show enough voltage at idle to charge your battery like mine does.
10-18-2011, 05:19 PM #8Former Mopar Man
- Jun 2011
- Branchville, NJ
Check for corrosion at the starter.
10-18-2011, 10:19 PM #9Junior Member
- May 2009
I went back through the posts and noticed that you said this condition only occurs when you turn the AC on. I missed that the first time. I would say everything is working like it's supposed to. The stock alt. doesn't run at sufficient rpms to pull the load of your electrical system when the AC is turned on because of the underdrive pulley. I bet mine would do the same thing if I had the AC connected. Maybe a custom alt. that will pull more amps at idle to power your AC. Turn the AC off when idling would be my only other suggestion.
They have inductive ammeters you can use for testing. Check the amp draw with the AC on/off. I have an underdrive pulley on my '89 Chev K1500 EC. When I drive on rainy nights with my headlights, wipers and defroster and fog lights on I run in to the same condition. I just pull too many amps and I have to turn something off to keep the battery charging. Under normal conditions it works fine.
10-19-2011, 03:15 AM #10
I do not recommend changing out parts until the actual problem is diagnosed. The A/C clutch is an electrical-mechanical device and there are probably some tests that can be done to determine if it is the issue. I would certainly not install a high output alternator and assume that it is going to automatically fix the problem.
10-19-2011, 09:19 AM #11
I wouldn't install a H.O. alt but a overdrive pulley may be needed... op is alittle low on voltage... underdrive pulleys slow down other accessories up front and if the alt. isn't spinning fast enough u will see the issues the op is. And overdrive pulley will solve that issue allowing the alt. to turn normal to make up for the underdrive pulley..
10-27-2011, 12:23 PM #12GET SOME
- Apr 2007
Thanks to all who have helped im currently still bs'ing with insurance over another issue then will get right to work on this..
11-28-2011, 12:34 PM #13
since you have a system, i would suggest a capacitor, it helps. I have one.
11-28-2011, 06:17 PM #14
11-28-2011, 06:52 PM #15You second that?
Originally Posted by az gt eater:2723291
idle issue.. may be tune issue.. help?
By okiels1 in forum General HelpReplies: 2Last Post: 12-07-2016, 02:17 PM -
pvc issue... vacuum leak....tune issue?
By okiels1 in forum General HelpReplies: 3Last Post: 03-05-2016, 09:10 AM -
Help: 02ws6 battery issue
By ws6 for life in forum Firebird / WS6Replies: 7Last Post: 12-13-2013, 02:09 AM -
Battery trade in dfw My Optima for your battery
By Lucky 13 in forum Parts For Sale / TradeReplies: 2Last Post: 04-10-2009, 03:33 AM -
Help: tranny issue think it might be planetary issue
By nerisls1 in forum Automatic TransmissionReplies: 6Last Post: 03-05-2009, 09:32 PM
