Thread: LCA relocation brackets.
10-11-2011, 12:55 AM #1Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Question... I installed on my car a set of relocation brackets.
The lower control arms are on the bottom holes.
Is it better to have them. On the top or bottom?
10-11-2011, 02:46 AM #2
I ran mine on the bottom. My understanding that you positively increase the geometry angle that way, which makes them more effective.
'02 ws6.....mods? nope
10-11-2011, 04:40 AM #3Senior Member
- Oct 2008
- Coral Springs, Fl
Since you are lowered the bottom is most likely the best for you, at stock height the upper hole would probably be most beneficial
10-11-2011, 12:39 PM #4Senior Member
- Feb 2010
Thanks guys. I ask because since I put them on. I feel like I lost traction.
I know my tires are not that good but tires spin every time I hit the throttle.
Is that normal or could be the tires?
10-11-2011, 12:57 PM #5Senior Member
- Oct 2008
- Coral Springs, Fl
could be a cause of the lowering springs, less weight transfer. good tires also help
10-11-2011, 06:53 PM #6Senior Member
- Feb 2010
I'm afraid to run drag radials but I guess I have no choice.
I also pulled out the spare tire, jack and all that stuff. To make it lighter but that was before I change the springs
Then the problem is I need more weight??
What other thing I need to do to fix this up?
Put the battery in the back?Last edited by 98maro; 10-11-2011 at 06:55 PM.
10-12-2011, 09:00 AM #7
putting weight over the back tires is alway a good idea but try the lca's in the top hole and see how it works for you there is alway a odd ball car out there may be you have it.
LCA's and Relocation Brackets.
By karpetcm in forum Suspension and HandlingReplies: 7Last Post: 08-16-2010, 09:58 AM -
Question: LCA Relocation Brackets
By rockojugs in forum Suspension and HandlingReplies: 8Last Post: 06-28-2010, 02:50 PM -
wtb: lca relocation brackets
By bobbyd in forum Parts Wanted / TradeReplies: 0Last Post: 05-05-2010, 03:33 PM -
WTB- relocation brackets
By stalker in forum Parts Wanted / TradeReplies: 0Last Post: 02-27-2006, 02:52 AM
