    Member jrgswhitels1's Avatar
    Feb 2007
    In front of you, where else?
    1993 Camaro Z28
    1998-2002 Airbox and lid question.......
    Anyone know if the Airbox and lid and stuff from the 98-02's Camaro/Firebird T/A work on the older 93-97 LT-1's? I swore that with little mods it is an easy bolt-on. Found a super mint set-up for cheap! Any comments or suggestions welcome. Thanks
    Waiting on the Tree transamtom's Avatar
    Niagara Falls Ont.Canada
    1999 TA A4
    I think you need a 93-97 Ram Air Hood if you have a 'Bird.
    You need the93-97 Ultra "Z" hood for a Camaro.
    I don't think it will fit under the stock hood without some serious modification(hole in hood).
    Indianapolis
    2000 WS6 6spd Hooker LT
    Don't know for sure if the '98-02 setup will work with a stock hood, but the SS Camaro for '96-'97 had the air filter on top of the intake of the LT1, not in front like the LS1s do and the WS6s had.
    Member bouigha123's Avatar
    Mar 2011
    MD
    1999 Formula ws6
    I have seen it done but you have to hack the car up pretty badly. The one that I saw had the fogs removed and air ducts in them up to the air box.
    Feb 2007
    1993 Camaro Z28
    I think I am going to make an aluminum radiator base support myself (or the polished unit that they do offer for LT-1's), then use a "stocker" lid because they are a bit shorter in height I think. Gonna have to engineeer a way to make the lid clip/bolt on though. The SLP lid looks to be fairly taller but Im pretty sure I can get away with the GM lid. However, the base looks to add some height to the lid and really hoping that with sheetmetal base, I might get away using the SLP lid. Hmmmmmmmmm.....Im thinking sticky for us LT-1 guys if I go ahead with this!
    Oct 2011
    Alanama
    97 trans am
    my 97 ta has ram air hood but someone removed the air box.can tha ls style ram air box be made to work since the 96 97 ram air boxes are hard to find ??
    Junior Member Y2KLS1Camaro's Avatar
    SoCal
    2002 Camaro Z28
    Setups are totally different. You could probably fab up a custom setup that would work better than a stock LS1 intake that would take less work.
  1. Wanted: Complete ram air airbox for 1998 Trans Am
    By Snosprt in forum Parts Wanted / Trade
    Last Post: 07-09-2010, 08:49 PM
  2. Replies: 2
    Last Post: 10-10-2008, 03:08 AM
  3. Lower Airbox WS6 1998-2002
    By PontiacFan in forum Parts For Sale / Trade
    Last Post: 01-10-2008, 06:08 PM
  4. Airbox Question
    By plesko02 in forum Firebird / WS6
    Last Post: 04-02-2007, 03:31 AM
