Results 1 to 10 of 10
03-28-2006, 08:16 AM #1Madeche Vision...soon
- Feb 2006
- Galveston, TX
NBM- '98 Ram Air Formula
4L60E and 4L65...Whats the difference???
60E vs. 65
What's the difference? My transmission shop was freaking out when they took my trans apart saying that I had a 65 not 60E even though it is written on the side of the trans. The mechanic was talking about how the input shaft was different and didn't have a step down on the end like other 60E's. They also talked about the pump or converter being different. Anyone have any idea of what i am talking about? Just trying to get some info.
04-01-2006, 06:00 AM #2Junior Member
- Winston Salem NC
Red- 2003 Vert
Here's how the 4L65-E differs from the 4L60-E:
* Five-pinion gears for input and reaction gearsets (versus four-pinion gears in the L60)
* Heat-treated stator shaft splines
* Induction hardened turbine shaft
* Heavier-duty low/reverse roller clutch
* Additional friction plate added to 3-4 clutch (seven plates versus six in L60)
* Shot-peened output shaft
* Revised valve body calibration.
04-03-2006, 06:00 AM #3Member
- Jan 2006
- Vienna WV
Silver- 98 Trans Am
Did the f bodies come with a 65?
04-03-2006, 06:29 AM #4
no they didnt
04-03-2006, 10:56 AM #5Madeche Vision...soon
- Feb 2006
- Galveston, TX
According to the trans shop, mine did. May have been something the previous owner did but I sure he would have told me when I bought the car. What did the 65 normally go in?
04-03-2006, 10:58 AM #6Madeche Vision...soon
- Feb 2006
- Galveston, TX
Oh yeah, GOJO thanks for the info.
04-29-2006, 10:21 AM #7Junior Member
- Apr 2006
sounds like you lucked up and got a tougher tranny
05-01-2006, 03:10 PM #8Madeche Vision...soon
- Feb 2006
- Galveston, TX
Maybe, but it still needed a rebuild.
05-09-2006, 11:25 AM #9Mrs.'s Boobies
- North Hollywood, Ca
Onyx Black- 2001 Camaro SS
Sounds like your trans builder has only worked on LT1 and older 4L60Es and TH700-R4s. Any reputable trans shop knows that the LS1 4L60E had a different converter due to the input shaft being longer for the LS1. That makes the pump different as well as the input shaft. Find another trans builder if this guy thinks you have a 4L65E in your car, he probably hasn't seen an LS1 4L60E, let alone a 4L65E.
4L65E came out in 2003 on trucks only, in 2004 some Corvettes and GTOs had them as well, they have been phased in to replace the 4L60E at the factory. Replacements for 4L60Es (LS1) are still plentifull.Last edited by 12secSS; 05-09-2006 at 11:28 AM.
05-09-2006, 12:25 PM #10Madeche Vision...soon
- Feb 2006
- Galveston, TX
Thanks, thats the info that I wanted. Looks like you sure know your stuff.
By Sarge in forum Almost Anything GoesReplies: 56Last Post: 10-07-2009, 06:09 PM -
By AB'sLs1 in forum External EngineReplies: 3Last Post: 06-27-2008, 09:58 AM -
whats the difference
By vytamenc in forum General HelpReplies: 5Last Post: 02-14-2008, 09:53 AM -
By T/A36 in forum External EngineReplies: 0Last Post: 09-26-2007, 05:55 PM -
'95 4L60E vs '01 4L60E biggest difference?
By kgrantkey in forum Automatic TransmissionReplies: 9Last Post: 04-28-2006, 12:09 AM
