Thread: 4L60E to 4L80E
08-31-2011, 10:48 AM #1Junior Member
- Aug 2011
- Texas
black- 2001 Camero SS
4L60E to 4L80E
I'm wondering if anyone knows if a 4L80E will fit in my 2001 camero SS without mods? Also is there a advantage in swaping to a 4L65E?
08-31-2011, 12:20 PM #2Junior Member
- Aug 2011
- Marshall, TX
Pewter metallic- 2001 Pontiac Trans Am
The 80 has a longer tailhousing and will require relocation of the torque arm bracket or a different arm I think. And unless you're making big horsepower, an 80 may be too much tranny. But not really sure. Was thinking on it myself last month when I had to rebuild my 60, again....
08-31-2011, 12:30 PM #3
The 4L80 swaps have been done into 4th gens. It requires some fab work. I thought the original PCM could be programmed to run it too with minimal work, but I can't remember exactly. It's been a few years since I've seen it done.
There are plenty out there, just not sure if any of them are on this board. Frost might be a good person to ask as I'm sure he has tuned such a combo before. There were several of them running around Cinci about 6-7 years ago when I was living there.
They are excellent trannies out of the box with a much better gear spread for drag racing.
05-24-2012, 09:37 AM #4Junior Member
- Aug 2011
- Texas
After a quick drive down the road again I have noticed that the transmission is not going to 4th at all, it stays in 3rd but when I back off the gas peddel the engine drops in rpm and seems to be free wheeling until I push the gas again. I can feel the TCC enguage but not sure if it's completely locked.rpms dont seems to change much at all if any.
05-25-2012, 01:27 PM #5
Trans fluid level is critical with the 4l60e.
Have you checked it while the car is hot and running?
Side note. It's Camaro, not "Camero".
From what I understand the 4l80e is a good trany, but as FBJ says some fab work will be required amoung other things.
I believe you'll have to modify the tunnel aswell.
Question: 4l60e or 4l80e
By twoolley08 in forum Automatic TransmissionReplies: 38Last Post: 10-28-2008, 03:03 PM -
4l60e or 4l80e
By twoolley08 in forum DrivetrainReplies: 10Last Post: 09-23-2008, 05:59 PM -
help,t56 to 4l60e or 4l80e swap
By 00ls6camaro in forum Automatic TransmissionReplies: 10Last Post: 06-26-2006, 05:10 PM -
By 00ls6camaro in forum General HelpReplies: 0Last Post: 06-11-2006, 11:33 AM -
700R4 or 4L60E or 4L80E???
By HotRodV6 in forum Automatic TransmissionReplies: 11Last Post: 11-15-2005, 04:09 PM
