Results 1 to 1 of 1
08-31-2011, 06:59 AM #1Junior Member
- Feb 2011
- Florida
Black- 1966 Chevy
Aftermarket fuel rail on LS1 project
I need some advise on installing a new fuel rail. I have an Ls1 engine with Ls6 intake and injectors. The engine came with Bosch fuel rail with one port. I wanted to add a return line and not use a corvette type regulator the engine builder suggested with the Bosch rail. The Bosch fuel rail has the clips to hold the top of the injectors in place. The new aluminum rail with 8 AN inlets, 5/8 diameter fuel intake, does not line up with the mounting holes. It looks like it's off 1/2 inch or so and the spacings is also off. needs an additional 1/2 to 1' lift.
Do I need clips?
any additional parts to use this rail?
I wanted these rail to flow more fuel as I'm building my car from the frame up and mush add new fuel line anyway. So my thinking is use 1/2 line to tne engine and 3/8 return with a Aeromotive stealth 340 in-tank pump and a regulator to keep the fuel pressure near 58 Lbs.
My project: 1966 Chevy II
Swartz Performance G-force frame teir II
373 gears, adjustable shocks, wilwood brakes.
Schwartz Performance, Inc.
Engine
2000 Ls1 aluminum block
Ls6 Patriot heads
Comp Cam (I will add model # later)
10.9 compression
100 mm Throttle body (cable)
Ls6 intake (mounted with large spacers?)
42 pound injectors
MSD coils
2002 Camaro (accessories, A/C, PS)
T-56 speed transmission
Pro 5.0 shifter
Mcleon twin clutch
Mcleon steel flywheel
I still need the A/C system
EFI Fuel tank
LS radiator
Mini tub and transmission tunnel work
But my frame is only days away from delivery and I'll get started peicing it together.
[IMG]dscn9102(1)[/IMG]
FAST 102 aftermarket Ls1 fuel rail?
By seweber in forum External EngineReplies: 2Last Post: 02-18-2015, 09:56 PM -
For Sale: LS1 Fuel Rail Covers with 2 Fuel Line Cutouts - Cut for F-Bo
By '99 SLP#24 in forum Parts For Sale / TradeReplies: 2Last Post: 01-11-2011, 06:24 PM -
is there really any gain to switch to a aftermarket billet fuel RAIL?
By greatwhiteZ28 in forum General HelpReplies: 2Last Post: 05-10-2007, 03:48 PM -
Removing fuel supply line from fuel rail
By GatorSS in forum General HelpReplies: 8Last Post: 01-02-2007, 05:10 PM -
WTT Vette Fuel Rail Covers For Fuel Rail Covers
By LS1GMCTruck in forum Parts For Sale / TradeReplies: 1Last Post: 08-27-2006, 05:54 AM
