Results 1 to 10 of 10
    Junior Member midnitejam's Avatar
    Parma, Ohio
    1998 WS6
    Taming the Loudmouth 1
    I'm running a 98 WS6 with Cam, LT's, 4.56 gears, 6 speed, and loudmouth 1 catback. I have a distinctive resonating zone in the RPM range from 2.5K - 3.25K rpm's that is obnoxious. As the revs pass through this range, the db's increase 10 fold from before and while in that rev range the exhaust note has an obnoxious cackling characteristic.
    What is generating the resonance and how can I eliminate it or tone it down?
    Does anyone else have an aftermarket cat back and a resonating zone in the rpm range? Have you done anything to eliminate the resonance?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Are you running cats? If not, there is your answer. Catalytic converters act as resonators as well as air purifiers. You could get an LM2 resonator and swap that in for the LM1 you have now. You could try a pair of resonated exhaust tips from any of our sponsors or eBay. Let us know if you need anything else.
    Coral Springs, Fl
    Sunset Orange Metalic
    kind of common in that rpm range, my best advice to you is find yourself a magnaflow catback, it will tone it down a bit and pretty much guaranteed to sound badass with the cam and LTs
    North Jersey
    2004 GTO M6
    I helped install a Magnaflow catback on a fellow member's Firehawk. Sounds total badass.
    May 2010
    Wilkes-Barre, PA
    Black/Black
    98 WS6/04 Sierra Dmax
    Love the sound of my cam with the magnaflow, almost just as much as the open cut out
    Member Edward-T's Avatar
    Jun 2011
    N.C.
    Blue
    2002-WS6
    i had the loud mouth when i got mine, couldnt handle all that racket, the only time it sounded good was at 6 or 6500, swapped it out for a flowmaster cat back and that sucks too, its going very very soon and i will be getting a magnaflow, i had one on my 95 with LT's and it sounded awesome.
    Parma, Ohio
    1998 WS6
    Thanks to everyone for your help. I keep hearing magnaflow--must be something to it. My take at the moment is to switch out the LM1 for the LM2 resonator. And if the LM2 offers no solution, then I'll try to find the resonator tips mentioned above.
    Is anyone running the electric cutouts and how do you like them?
    May 2010
    Wilkes-Barre, PA
    Black/Black
    I have an electric cut out, makes it so much eaiser. Before I would have to jack the car up to take the plate off. Now I can open and close it anytime I want to.
    North Jersey
    2004 GTO M6
    Member PAJeff02 has one in his WS6. I heard it and it sounds VERY nice. :yep:
    Also...with the Magnaflow, you will have a nice, mellow cybernetic growl. Sounds so evil.
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    You will have the same issue with the LM2
  1. WTB SLP loudmouth
    By SLDWS6 in forum Parts Wanted / Trade
    Last Post: 06-18-2010, 10:56 AM
  2. Taming the Dragon with the 'Hawk
    By bberretta in forum Firebird / WS6
    Last Post: 04-25-2010, 09:22 PM
  3. Slp loudmouth 2
    By whiteLS1TA in forum Firebird / WS6
    Last Post: 06-27-2007, 06:12 PM
  4. SLP Loudmouth
    By jerseyss in forum General Help
    Last Post: 04-16-2007, 06:12 PM
  5. anyone got LTs and Loudmouth II?
    By snake_skinner00 in forum External Engine
    Last Post: 03-17-2006, 07:14 PM
