08-21-2011, 12:29 PM #1Senior Member
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
Possible tranny issue with 95 dodge ram?
first off i hope its ok i post this here, being as it is specific for lsx vehicles....i didnt know where else to post this. mods, if it is in wrong section feel free to put in the correct forum.
Ive had this truck for over a year now, and it has done this ever since ive owned it. i had the tranny flushed new filter installed and synthetic fluid put in (not cheap). but the issue still goes on. what it does is, when driving it acts like a normal truck, but when you let off the gas to slow down or whatever, the rpms drop straight down to an idle. where as most vehicles when you let off the gas the rpms stay where they were when your driving. but i dont know why mine drop to idle. also, if you let the truck sit for more than 2 days it will lose line pressure, as in if i start it after 2 days and put it in gear, it wont move for a bit until it gets pressure again and will take off. i prevent this by starting the truck and putting it in neutral for about 30 seconds before i take off and its fine doing it this way. but i would think it shouldnt lose line pressure after 2 days of sitting. ive included a short video of what my truck does when driving and letting off the gas. any help, ideas, or information would be appreciated. id like to get this figured out while its still nice out to where i can fix it....im leaning towards the possibility of the torque converter going out. although it still shifts like normal, and the torque converter still locks up normally.
08-22-2011, 07:13 PM #2Senior Member
- Apr 2008
- Madison, WI
Losing pressure after a few days is a common problem with those Chrysler RWD transmissions. My Jeep (5.3 V8) did that. The converter is draining back and it takes time to refill it. there is a service bulletin for it. the fix was to add a check valve somewhere.
08-24-2011, 07:05 AM #3
The lagging issue may be deeper, does it have a lazy 1,2, 2,3 shift ?
It's not dropping to idle, it is dropping off some, every trans i have seen with that wait to warm up issue has a deeper problem, sounds like its what happens when they sit in park idling a lot, the older dodge trans do not circulate in park, why it's not good to let them sit in park running, always neutral, and why you check the fluid in neutral
08-24-2011, 10:32 AM #4Senior Member
- Jul 2006
- Greene, Iowa
No lazy shifts at all. And yes I know the pump is not engaged in park thus the reason why I let it warm up a neutral like my original post said
pvc issue... vacuum leak....tune issue?
By okiels1 in forum General HelpReplies: 3Last Post: 03-05-2016, 10:10 AM -
Help: tranny issue think it might be planetary issue
By nerisls1 in forum Automatic TransmissionReplies: 6Last Post: 03-05-2009, 10:32 PM -
Possible Tranny issue
By Spikito in forum DrivetrainReplies: 6Last Post: 10-30-2008, 07:13 PM -
tranny issue
By bmred99ws6 in forum Automatic TransmissionReplies: 4Last Post: 06-28-2008, 08:20 PM -
If you can dodge a bilboard you can dodge a ball
By ss~zoso~ss in forum Multimedia SectionReplies: 13Last Post: 02-04-2007, 06:49 AM
