Thread: Air/Fuel Ratio Gauge question
08-14-2011, 01:44 PM #1Junior Member
- Dec 2009
- Georgia
- RV-10
I've had two Bosch O2 sensors go bad on me - at least that's what the code says. I can reset the code, but it eventually comes back. I saw a YouTube video on how to test an O2 sensor IF you have an Air/Fuel Ratio Gauge. I've looked at Summit, AutoZone, etc., and the prices go from $50 to $300. There also seems to be a "sender" that is sometimes required.
If I just want a cheap setup to use on a bench to see if the O2 sensor is good, what do I really need?
John
08-14-2011, 03:14 PM #211 years of bangin gears
- Jan 2009
- North Jersey
If you want something on the cheap, then you can get an A/F ratio gauge from Summit. I am not familiar with how all 4 sensors are wired, but on my old Chevy Beretta, I tapped into the O2 sensor wire. I don't know if there is one wire to the BCM and then 4 wires coming out.
08-14-2011, 03:19 PM #3
You can test them with an Ohm meter. http://mr2.com/TEXT/O2_Sensor.html
08-14-2011, 03:22 PM #4
I would suggest determining what is causing them to go bad. You probably have a vacuum leak, or it's possible that the wiring loom may be hitting the header/exhaust and has burnt through it causing damage.
Air Fuel Ratio Question
By SMWS6TA in forum General HelpReplies: 19Last Post: 02-02-2017, 11:55 AM -
Question: Fuel gauge question
By 02silverbird in forum Appearance SectionReplies: 20Last Post: 03-19-2011, 10:56 AM -
Question: How to connect air/fuel ratio gauge?
By Cali Night Stalker in forum General HelpReplies: 37Last Post: 08-10-2009, 04:24 AM -
Boost gauge - A/F ratio gauge - & RH mirror cover
By 9t8z28 in forum Parts For Sale / TradeReplies: 3Last Post: 01-24-2009, 03:18 PM -
air fuel ratio gauge
By coupe00 in forum Camaro / SSReplies: 8Last Post: 02-14-2007, 01:27 AM
