Results 1 to 20 of 25
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    Adjustable or non adjustable LCAs?
    So I want to get LCAs soon, but as with most parts, theres adjustable, and non versions.
    what are so pros and cons of both?
    My main reason for getting them is to just stiffen up the suspension a little, cars a DD, nothing fancy
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I may be getting adjustable's now since when I swapped out my 9" and got my PST drive shaft installed there is little to no play in the yoke.
    I need to move my rear end back about 1/2".
    I personally like adjustable everything. You never know when you might need to adjust something later down the road such as what I'm currently experiencing.
    I don't think there would be any disadvantage to adjustable other than them costing a little more. With non-adjustable, like I have, you basically are stuck with what you got. For most applications, that works fine...but when you start changing out things such as your rear end or putting slicks on the car, the adjustment is needed.
    2000 SS Black M6
    yeah i know...my only problem is that adjustable is just that...adjustable...
    I'm worried that since my car is a DD, things might start adjusting themselves.
    but since i plan to lower, and I'm sure ill have a new rear at some point, it may be worth it
    Marylandistan
    2001 Trans Am (sold)
    I have slicks and a 12 bolt rear and run Spohn non adj poly lcas. No issues and no need for adj ones here. I'm not saying do not get adjustables, just in my case they were not needed. I always recommend adjustable panhard rods and torque arms tho.
    Coral Springs, Fl
    Sunset Orange Metalic
    In my opinion for the added costs of adjustable LCAs, it's worth it to me. The ability to move everything around is great.
    It helps a lot too in centering the wheels in the wheel well
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I got adjustable since my car is lowered. Wanted to center my rear.
    Senior Member 98maro's Avatar
    Feb 2010
    north bay california
    00 camaro ss M6 #6695
    get the adjustable "on car adjustable" i got some single adjustable and im not to happy with them
    Pa
    Hello,
    Since the car is your daily driver I would recommend the non-adjustable set up. Adjustable control arms allow the rear end to be centered, this is usually only needed when installing an aftermarket rear end like mentioned or when trying to get more room for larger tires.
    If you would have any questions I can help with please ask. Thank you!
    Ryan
    2000 SS Black M6
    thanks for the info, I've been looking at the UMI parts for suspension.
    no slicks here, but I am running 295/35/18s. BFG KDWs
    Pa
    Glad to hear, we offer a very nice product line and I assure you wouldn't be disappointed.
    As long as you aren't having clearance issues now then you won't with new control arms. You should be fine with this size tires.
    I hope that helps!
    Ryan
    2000 SS Black M6
    my stock LCAs give me about 3/8s of an inch clearance, lol
    Dustin you must have been reading my mind, I was just thinking about this very subject. Now I have my answer thanks.
    2000 SS Black M6
    I love when you get on here and find the exact thread youre looking for on the front page
    I'm going to go with UMI adjustable because I plan on getting a 9" rear so I don't want to by LCA's twice.
    2000 SS Black M6
    http://kyspeed.com/index.php?main_pa...products_id=69
    Im liking these
    http://kyspeed.com/index.php?main_pa...roducts_id=674
    I can't see any real difference in the first one, or these, except where the adjusting bolt is located. maybe Ryan can chime in
    The more expensive ones have the roto-joint on the one end where the other ones have poly bushings in both ends.
    2000 SS Black M6
    whats a roto joint? lol
    It's a spherical mount which is supposed to alleviate any suspension bind. Works like a ball and socket...kind of like your shoulder
    2000 SS Black M6
    oh i see
    2000 SS Black M6
    damn, i can NOT find any install instruction or pics for LCAs
  1. How to Install UMI adjustable LCAs
    By Spikito in forum Suspension and Handling
    Last Post: 09-16-2011, 10:17 PM
  2. Adjustable LCAs
    By firemandan1700 in forum Parts Wanted / Trade
    Last Post: 08-16-2010, 02:24 PM
  3. For Sale: UMI Non-Adjustable F-Body LCAs
    By Fran D in forum Parts For Sale / Trade
    Last Post: 05-08-2008, 07:37 AM
  4. Non Adjustable LCAs and relocation brackets.
    By robs98z in forum Suspension and Handling
    Last Post: 04-26-2007, 06:37 AM
  5. adjustable lcas
    By FuriousGeorge in forum Parts Wanted / Trade
    Last Post: 10-06-2006, 05:32 PM
