Thread: jerking
08-01-2011, 12:01 AM #1
jerking
Whenever I put the car in reverse or drive it jerks the whole car. What is causing this?
08-01-2011, 05:01 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Is it the entire time you are in gear, or only when you first shift into gear?
08-01-2011, 11:44 AM #3
It does it sometime while in gear. I thought that was from when frost tuned my car.
08-04-2011, 09:20 AM #4
Im Guessing your Cammed and a A4. My car does the same thing sometimes at lower speeds and going into reverse. My tuner says it cause I havent swapped to a larger stall yet so they dont match up correctly. Now I have the issue but should be solved soon, have 3600 stall and flexplate in the closet, along with 3.73 gear to install as well. Then a complete new Dyno tune
08-26-2011, 07:32 AM #5Senior Member
- Apr 2010
- Alabama
My car does this too but I am not cammed. But its only when I first put it in reverse and when I first put it in drive. I did recently have a tab replaced on my shifter and it started just after that. So I dunno exactly why it does it.
1998 Trans Am WS6 - Phantom
421 LQ9 14.8:1 on E85 Build/
09-20-2011, 07:31 AM #6
mine does it too when i go from park to reverse or to drive, or from reverse to drive or vice versa. it kinda makes a little ping noise when it does it. im gonna check the ujoints this weekend. i also read it could be the epc ( electronic pressure control valve) in the transmission. anyone had problems with this??
HELP ! Bucking and jerking when trying to maintain speed!
By 5abivt in forum General HelpReplies: 91Last Post: 04-24-2011, 11:36 PM -
close the sun roof when jerking off
By 02Sweet in forum Almost Anything GoesReplies: 18Last Post: 05-08-2009, 08:29 PM -
Severe hesitation/jerking
By grandkodiak in forum LT1Replies: 42Last Post: 04-01-2007, 02:46 PM -
Jerking/Shuddering still
By freshduckie in forum General HelpReplies: 18Last Post: 04-16-2006, 05:16 PM -
Wheel jerking over bumps - normal?
By BlackHawk T/A in forum Suspension and HandlingReplies: 6Last Post: 08-28-2005, 02:45 PM
