Results 1 to 13 of 13
    WA
    silver w/black stripes
    2001 WS6
    Engine swap help/question?
    So i just had my 2001 ws6 T boned, and wanted to know if i could swap the engine into a same "gen" v6 firebird/camaro. and upgrade from there? note- the only reason i want to swap into a v6 version is because they are cheaper.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    If the V6 has power options like your previous car, then take the PCM, BCM, wiring, engine and trans and swap everything over. HOWEVER, if the trannies are different between vehicles, you will need to install a clutch pedal if the recipient happens to be an automatic. I could be missing steps, but others will chime in. Let us know if ya need anymore help.
    WA
    2001 WS6
    haha okay thanks that dose help. um i'll just get a 5 speed v6
    phoenix
    04 2500 4x4 crew cab
    That's probably the easiest. Unless you can sit on your money till you can A- find a ls1 for what you have B- save till you have what you need. You can find ls1's cheap sometimes.
    WA
    2001 WS6
    yeah but even a cheap ls1 camaro/trans am would be 7 large, and the thing is. there is a 2000 v6 camaro going for $700 right now so thats why i'm asking.
    North Jersey
    2004 GTO M6
    Hopefully that car is in good shape. That price seems awfully low for even a 6 cylinder bird in good shape.
    you're probably going to spend the same amount of money on a engine swap and you'll end up losing a lot power... i'd check e-bay or even see about building a engine from a LQ9 or something out of a junk yard...
    WA
    2001 WS6
    well goos news i think i can keep my car. i found a body shop that can fix frames. and do damn good job. so i think i'll just go that rout because it's ilke impossible to find ws6 anymore
    North Jersey
    2004 GTO M6
    Keep your fingers crossed.
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    if you have you totaled car and the v6 swap car side by side the swap is going to be easy and wont cost you a dime once you buy the v6
    Member jsmith564`'s Avatar
    Apr 2009
    covington ga
    yellow
    2004 gto
    pix of damage
    Pittsburgh
    2008 Hummer H3
    You can not use the v6 tranys in any form.. All v6 F-body transmissions use the 60* v6 bell pattern..
    A stock LSx would destroy a 5-spd trans in a few heart beats anyways.
    Tho internally the v6 4l60e has the same guts as the lsx 4l60e, again the bell wont match..
    You also can not use the v6 PCM unless you modify the pinouts/harness..
    The BCM, from a loaded v6 may not be useable even if the WS6 was also loaded..
    A swap over would require some work but it has been done many times over..
    I see you desided to fix the WS6 anyways.. Prolly the better choice..
    phoenix
    Glad to see it worked out for you. Cutting and splicing should always be a last choice.
  1. Question: Planning an engine swap, question regarding motor mounts
    By Biggyniner in forum External Engine
    Last Post: 05-25-2014, 02:58 PM
  2. question about engine swap . please help me out here?
    By bdub2145 in forum LS2/LS3/LS4/LSx
    Last Post: 10-07-2010, 05:07 PM
  3. Engine swap and computer swap
    By mrmiatanut in forum Computer & Tuning
    Last Post: 09-08-2007, 06:10 PM
  4. Engine Swap Question
    By 95camaro in forum V6
    Last Post: 07-28-2006, 09:32 AM
