    Junior Member black2kSS's Avatar
    Nov 2010
    cheektowaga, ny
    2000 camaro ss
    stage 2.5 5.3L heads and TV2 cam
    Has anyone on here ran this combo and if so did you have any problems with the higher compression? wondering if pump gas is ok for this combo (93 near me)? I also understand that a tune would be a must after this so all timing and fuel adjustments would be made then. Just curious to hear any real world reviews.
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    Quote Originally Posted by black2kSS View Post
    I ran this exact combo before I threw a rod due to an unrelated issue. My heads were milled (to reduce the combustion chamber size) and my compression was just shy of 12:1. I'm 100% confident you'll be fine with non-milled heads.
    What intake manifold and injectors are you going to be running?
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged w/ a T67 Turbocharger
    2007 Chevrolet 3500 Dually Duramax: 3" Downpipe, Dual 4" Exhaust, EFILive Tuning
    Nov 2010
    cheektowaga, ny
    2000 camaro ss
    i currently am putting ls6 and ported stock TB on for intake. just thinking into the future a little here. is an injector change needed? is there any stock injector that will swap over?
    Laurel, Maryland
    2000 Grand Prix GTP
    LS6 is a good choice, I was using a FAST90mm and Holley 90mm TB. You'll probably be around 425 rwhp with that setup.
    I was using 38# injectors...not sure if you'll max out the stock injectors, but you'll definitely be close.
    FASTER THNA SPEEDINtICKEt BANDITO's Avatar
    A, A
    2002 trans-am
    ^_^
    blah '02 WS6's Avatar
    white deer, tx
    '02 trans am ws6
    Ran it and liked it (GTP stg 2+ heads though).....until I ran a custom grind cam spec'd for my LS6 heads and realized I shorter myself the first time by not getting a proper matched combo tailored to my heads.
    '02 ws6.....mods? nope
  1. Prc stage 1 ls6 heads v2 cam?
    By Z28SMG in forum Internal Engine
    Last Post: 08-17-2011, 11:56 AM
  2. Patriot Ls6 Stage 2 vs TSP 5.3 stage 2.5 Heads
    By jetaws6 in forum Internal Engine
    Last Post: 11-16-2010, 06:11 AM
  3. PRC 5.3l Stage 1.5 Heads VS. PRC LS6's
    By sfletch2000 in forum Internal Engine
    Last Post: 09-10-2007, 11:32 PM
  4. F/S: 231/237 TSP cam & Stage 2 LS6 heads
    By Y2KPewterSS in forum Parts For Sale / Trade
    Last Post: 04-22-2007, 11:42 PM
  5. Stage 1 ls1 heads FS
    By Blksilvr in forum Parts For Sale / Trade
    Last Post: 09-20-2005, 06:36 PM
