Results 1 to 13 of 13
    Milwaukee
    Liquid Red
    2008 Pontiac G8 GT
    How to tell if a Camaro is a real SS
    I work for a dealership and we're looking to buy an SS for our store. The one in question has several aftermarket items (side skirts, front/rear bumpers, hood) and a few goodies under the hood but nothing major. Since the original hood is long gone and so are the wheels, I have nothing else to go on. Will a VIN tell me if it's a real SS? RPO code?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Yes to both. The RPO code is WU8.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Quote Originally Posted by Red97GTP View Post
    What year of Camaro are you looking at?
    Good question. The RPO code I listed is for 97 and newer I believe.
    Milwaukee
    Liquid Red
    2008 Pontiac G8 GT
    It's a 99. Also, the car is here right now. We put it up on a lift and we noticed something funky. At the rear of the trans there are two sensors that connect to factory harnesses that look odd. They have small retangular gray boxes on them with a small red LED light in them. They run on both sides of the trans. They look like 02 simulators but they aren't. The car does have deleted cats with headers with the factory 02 sensors in them, but they are connected to a harness already. There is a CEL on as well, we may have to scan it to find out what's up with that too, maybe they're connected. Any help on the gray boxes??
    USA
    Velocity Yellow
    2008 Corvette Z06
    Can you get a pic?
    Arizona
    Well you got me with the grey boxes and led lights. The only thing that should be on the trans at the very back would be the speed sensor, and that's a small plug with 2 wires in it. You didn't mention which trans you have, but what I mentioned is the same for both the manual and the auto.
    All I can suggest would be the scan the codes that are present and see if it's related.
    Milwaukee
    Liquid Red
    2008 Pontiac G8 GT
    The car is an auto. We figured out that they are "cheaters" for the O2's. They are not working properly causing the CEL.
    Arizona
    Ah, so it was related to the check engine light then. That's an easy fix for ya.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    If it doesn't have or need cat's then you can tune out the rear O2's as all they do is measure cat efficiency.
    Like stated a 4th gen SS will have a "WU8" code on the door or you can enter the VIN into the GM database and it will tell you everything about the vehicle.
    Milwaukee
    Liquid Red
    2008 Pontiac G8 GT
    Thanks for the help 67. We're buying the car on Wednesdag and we're taking it to get dyno tuned right off the bat and get the O2's taken care of. Also, do you have a link to the VIN database? The RPO code sticker was a bit worn out and we weren't able to read the whole sticker.
    USA
    Velocity Yellow
    2008 Corvette Z06
    If it's a 99, chances are the RPO list is no longer available through GM's database.
    I believe in 99, SLP still was converting the cars to SS's. You may try contacting them and seeing if they can't tell you by the VIN number. I honestly don't know when SLP started doing this though.
  1. Real 1998-2002 Camaro SS Spolier
    By IT_SS in forum Camaro / SS
    Last Post: 11-13-2009, 05:10 PM
  2. Question: Is this a Real SS Camaro?????
    By bignadad in forum Camaro / SS
    Last Post: 10-26-2008, 08:08 AM
  3. Can someone tell me if this is a real SS camaro?
    By importssuck in forum Camaro / SS
    Last Post: 02-12-2008, 06:29 PM
  4. SS Camaro real or not real??
    By odarabla in forum Camaro / SS
    Last Post: 11-28-2007, 11:26 AM
  5. camaro man is a real person
    By zero_proto in forum Multimedia Section
    Last Post: 04-04-2007, 02:05 PM
