Results 1 to 10 of 10
07-24-2011, 08:38 AM #1
Installing a clarion in my Camaro
Hi guys,
Once again I need your help. I am trying to install my clarion head unit in my 99 Camaro I honestly know shit about electronics and was wondering if there is a plug and play option or do I need to start splicing ..... Here are the pics of the radios
By stock monsoon on the top and a clarion vx401 on the bottom
07-24-2011, 11:32 AM #2
you going to need an adapter harness or get out some wireing diagrams and find what wire does what and start splicing/crimping/soldering/or w/e you want to use
07-24-2011, 03:13 PM #3
If the clarion is a double din, you do know that you will have to trim your bezel or find someone that makes one, right?
LS6 Intake, LS6 VCT, E^2 Catch Can, Hooker LTs and ORY, Magnaflow Cat-Back, 3" QTP electric cutout, UMI adj LCA, PHB, 3 pt SFCs, STB, MGW Shifter, SLP lid and bellow, Free-Mods, Tuned by BlueCat
07-24-2011, 03:50 PM #4
Best thing you can do is lay all new wire for your speakers. Don't you have the Monsoon system? Then there is an amp built into the car.That amp is going to mess with your new signals badly. The amp runs all the speakers except for the tweeters in the door. And those tweeters have built in crossovers. You will want to bypass the amp. The wires in the car are what? 18-24 ga? Those are not gonna help you transfer power to the speakers. And what impedance does the stereo run? You need to match the ohms of the speakers to the ohms that the stereo is putting out. Some hu's have the ability to switch ohm's from 2 to 4. Clarion is a nice deck. Maybe you can do that.
07-24-2011, 08:05 PM #5Member
- May 2009
- Central Florida
red- 2000 Z28
Metra makes a widely available harness that will plug into the harness on your headunit. You could continue to use the stock monsoon amp with stock speakers and still sound stock. You could replace the stock speakers with component separates (I cut holes to flush mount and angle the tweeters in the door panels above the woofers) using the stock speaker wires to power the woofers and tweeters which will be a massive sound quality upgrade depending on your speaker choice. I used reasonably priced Infinity Reference 6.5" components up front and coaxials in the rear, knowing the coaxials would only repoduce the bass signal they are fed by the monsoon amp. They sound a ton better than the original speakers even with the monsoon amp. Or you could replace it all and run a new headunit, amp, speakers and sub. It all depends on your ears and budget.
Sent from my DROID2 using Tapatalk
07-25-2011, 02:37 AM #6
Stupid question where can I find the monsoon amp?
07-25-2011, 07:10 PM #7
07-26-2011, 12:59 AM #8Member
- May 2009
- Central Florida
red- 2000 Z28
Under the passenger side rear interior cover by the spare tire.
07-27-2011, 08:35 AM #9
Pacific Accessory Corporation makes all kinds of adapters.
http://www.pac-audio.com/2000 T/A-DMH Cutout, SLP Cold Air kit, FTRA/SLP Upgrade, SLP Bilstein, LT1 Eibach ProKit, Kuhmo PA31 Tires ,SLP Fan Switch, UMI Double Adj PHB w/ Roto-Joints, UMI LCARB, Strano 35/22mm Sway Bars , Magnecor KV85 Wires, Hurst Shifter, Lou's Short Stick.
09-16-2011, 04:00 AM #10
Still need to get it centered and need a dash kit but it's alive!!!!!!
Help: Installing WS6 seats in a 2002 Camaro
By bmvfdcaptain in forum General HelpReplies: 4Last Post: 06-23-2013, 07:06 PM -
Installing A 770 Holley In A 1979 Chevy Camaro - C
By Ed Blown Vert in forum Camaro / SSReplies: 1Last Post: 05-13-2009, 01:40 PM -
installing aftermarket highs in 02 camaro
By williams2k4 in forum Stereo and ElectronicsReplies: 8Last Post: 04-19-2007, 03:25 PM -
AIr Up - Installing Air Bags On A First Gen Camaro
By Ed Blown Vert in forum Camaro / SSReplies: 3Last Post: 09-27-2006, 06:36 PM
