Results 1 to 3 of 3
Thread: Trans am Tranny problem
07-19-2011, 12:47 PM #1Junior Member
- Apr 2010
- Sterling Heights, MI
Navy Blue Metallic- 1998 Trans Am
I have a 1998 Trans am a4 witha B&M shift kit and stronger trans mount for obvious reasons....anyways i threw my powershifter on the other day and when it shifted even at low rpm (2500 or so) it makes a very loud thud and it doesnt sound healthy...also even when its off and i punch it into 2nd it makes the noise as well i feel it in the center console sort of lol it jolts the whole car and also my trans leaks just a little every night so i checked my fluid and it seemed a little high and there was a little bit of green fluid next to it as well....HELPPPP!!!!!!!!!!
07-19-2011, 12:59 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
Check your engine and tranny mounts. I know you said you are running a stronger tranny mount (I'm assuming you mean a poly mount), but that doesn't mean it isn't bad. Also, if you are still running a stock torque arm, check the tailshaft of the tranny and the torque arm mounts.
07-19-2011, 01:24 PM #3Junior Member
- Apr 2010
Anyone Have this problem with A4 Tranny?
By 96Firebirdformula in forum LT1Replies: 6Last Post: 10-17-2007, 04:06 AM -
is it a clutch problem, or a tranny problem?
By sgt0704 in forum Manual TransmissionReplies: 3Last Post: 01-07-2007, 05:03 PM -
tranny problem?
By BlueByU-SS in forum Camaro / SSReplies: 0Last Post: 10-01-2006, 11:51 PM -
problem with tranny (i think) need help!!!
By baseballss in forum Manual TransmissionReplies: 4Last Post: 11-24-2005, 04:08 PM -
SERIOUS Tranny Problem! HELP!!!
By GTObsessor in forum Manual TransmissionReplies: 7Last Post: 10-25-2005, 07:19 PM
