Results 1 to 13 of 13
07-19-2011, 10:48 AM #1Junior Member
- Jul 2011
- Chicago
NBM- 2000 WS-6
New mod - Free engine bay heat extractor
I removed the weather stripping below the windshield wipers. I figure since I wash under the hood all the time, I don't need this strip to keep water out. I'm sure it lets a lot of heat out when moving. What do you think? Any gains?
Smasher
2000 WS-6, NBM, BGRA, Clear Lid, Delphi MAF, Bobbit EGR, FLP Long Tubes, SLP Loudmouth, STB, SFC, EradiSpeed rotors, Fire Hawks, and lots of Zaino
07-19-2011, 10:53 AM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
I doubt you'll see anything noticable. Might even cause problems with debris entering the engine compartment. Might be fine, too. I wouldn't expect a difference though.
07-19-2011, 11:03 AM #3Junior Member
- Jul 2011
- Chicago
NBM- 2000 WS-6
I was looking at the Firehawk hood that has the two extractors and I thought if they have them, there must be a reason.
07-19-2011, 11:19 AM #4None Shall Pass
- Jan 2010
Aesthetics, mainly.
07-19-2011, 11:28 AM #5Spaz is My Mentor
Also remember that strip helps protect the PCM from water too.
07-19-2011, 11:46 AM #6O U 8 1 2
- Nov 1999
- over here...
i tohught about doing this a while back... you can end up with water polling on electronics that shouldn't get soaked... gains would be possible but minimal... if you want super heat extractors buy a mecham titan hood...
07-19-2011, 12:05 PM #7Junior Member
- Jul 2011
- Chicago
NBM- 2000 WS-6
I've got a nice WS6 hood. Thought about making holes in it...., but changed my mind. I hose down the PCM and all other electronics regularly, so not worried. Does the LS1 engine make more power if it's cooled better?
07-19-2011, 12:14 PM #8None Shall Pass
- Jan 2010
Not with heat extractors. With lowering the fan settings and a cooler t-stat.
07-19-2011, 12:16 PM #9
07-19-2011, 12:22 PM #10
future candidate for a "my knock sensors are bad" thread. It's only a matter of time before you get water where water isn't supposed to be. The gains (if there are any) aren't worth the risk. Here's another one too......there's been instances where that weatherstip has leaked and allowed water to puddle on the intake. A bad injector seal let water into the cylinder. They turned the key and "boom" rod through the block. Just food for thought.
07-19-2011, 02:42 PM #11Senior Member
- Aug 2007
- Greensboro, NC
Pewter- 2002 Trans Am WS6 M6
I had a bad seal on my PCM last december. Water got into the PCM and it did all sorts of "wonders" for the engine. Including clogging both cats from not burning fuel correctly at times due to issues the PCM kept causing. Plus the on top of that my mechanic replaced seals on the intake all new spark plugs and a couple other things before we realized what the issue was. Which set me back another couple hundred. At least the car got a nice tune up out of it. I could of bought a nice set of headers or a true dual exhaust fixing all the problems a little water caused.
07-19-2011, 03:31 PM #12Junior Member
- Jul 2011
- Chicago
NBM- 2000 WS-6
07-20-2011, 06:56 PM #13
Hood/Heat Extractor lights
By robcas47 in forum Appearance SectionReplies: 16Last Post: 11-18-2010, 02:13 PM -
Question: Anyone have Heat Extractor Hood
By Mike's TA in forum Firebird / WS6Replies: 18Last Post: 11-25-2008, 10:28 PM -
single extractor hood
By thisisthewayilive in forum Camaro / SSReplies: 8Last Post: 10-24-2008, 07:32 PM -
Question: 4 port Heat extractor hood
By JTUCK in forum Camaro / SSReplies: 3Last Post: 05-26-2008, 08:24 PM -
engine heat
By GetSome04 in forum GTOReplies: 16Last Post: 07-31-2007, 05:14 AM
