Results 1 to 20 of 22
Thread: 6.0/4L60E swap done
07-12-2011, 03:07 PM #1
6.0/4L60E swap done
Well it's pretty close to finished. I'm still waiting on all the AC parts to get here, but it's up and running and back to daily driver duty.
I started with this
Here is the cross member to make it fit into an old 72 blazer
I went with a 4L60E with all the goodies inside to take some punishment. Advance Adapters made the necessary adapters to mate this thing to the old cast iron 205 transfer case. Here are some shots.
07-12-2011, 03:08 PM #2
Here it is resting in the blazer ready for the engine...
This is the new 205 transfer case mount that I decided to buy so I didn't have to modify my original
07-12-2011, 03:09 PM #3
Cross member installed for mock up.....engine went in and out 3 times before I was happy.
07-12-2011, 03:11 PM #4
And the engine finally installed for the last time....
07-12-2011, 03:12 PM #5
Here is the custom made wire harness from Howell, they also supplied a computer to run it all...
Very simple plug and play with extra goodies like manual fan control if I care to, as well as cruise control since this has a drive by wire setup.
07-12-2011, 03:14 PM #6
Dual electric fans pulled from a 4th gen in the bone yard....
07-12-2011, 03:17 PM #7
Here is how you make factory equipped mechanical gauges work with a modern LS engine.
I first pulled out the plug at the rear of the passenger side head....This is where the old temp sender for an analog gauge will go, in affect leaving the original temp sender in the driver side head for the computer to function properly.
Here is the difference in size
You simply drill and tap, install sender and run the original wire over to the passenger side....done.
07-12-2011, 03:19 PM #8
The mechanical oil pressure gauge is much simpler.
Just remove the plug above the oil filter held in by 2 bolts. Drill and tap with 1/8" pipe tap and then run your normal copper line with compression fittings, or go braided with 37* flares. Very simple, and it works.
07-12-2011, 03:24 PM #9
There is a ton of fab work here that I won't get into much, mainly because people wouldn't understand unless you are very familiar with these first gen blazers.
Things like cutting apart and moving the battery tray, the exhaust, the shift linkage, and it goes on and on....
But it's finished. AC parts are on the way. High mount AC compressor kit is from Kwik Performance. I custom made the air intake out of 4 inch piping from intakehoses.com to finish it off.
Right now I'm fine tuning this thing, tweaking shift points and what not. Seems to run strong despite the 3.07 gears and 33" tires.
07-12-2011, 06:04 PM #10
WOW!!! Very nice build! By the look of the engine cover, I'm assuming LQ4? That thing is gonna be a beast with that power plant.
That is just awesome.
07-12-2011, 06:23 PM #11
Yes LQ4 6.0 from a 2004 3/4 ton truck. It runs decent considering the gear and the tire. I'd like to see a little more pep out of it. But I've only begun to tune it too. So there may be quite a bit hiding yet. The timing tables were some of the weakest I've seen, and I haven't tinkered with the fuel tables yet.
07-12-2011, 06:39 PM #12
Very impressive... and super clean work.
07-13-2011, 04:57 AM #13
Thanks Jeff. I didn't spend too much time on it simply because it's a driver and I don't want something too nice for that. It did turn out cleaner than I had thought it would though.
07-13-2011, 06:13 AM #14
07-13-2011, 11:07 AM #15
07-13-2011, 11:07 AM #16
07-13-2011, 11:10 AM #17
07-13-2011, 11:14 AM #18
Ya figures. Sometimes they stay up for weeks, other times just days. After all that posting too.
07-13-2011, 12:39 PM #19Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
can u fix the pictures pls?
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
07-13-2011, 01:56 PM #20
I'm probably going to have to resubmit the pictures to photobucket and try again, since they removed them all. Not sure how long they will stay in there though. I've had this issue for a long time.
Swap from TH350 to 4L60E
By wayneinFL in forum Automatic TransmissionReplies: 5Last Post: 02-27-2010, 02:46 PM -
4L60e swap
By Spikito in forum Automatic TransmissionReplies: 8Last Post: 10-30-2007, 11:06 PM -
4L60E/T56 swap
By 96t/a in forum Manual TransmissionReplies: 0Last Post: 08-29-2007, 04:06 PM -
What do I need to do a swap from a t56 to a 4l60e?
By sscrazy in forum DrivetrainReplies: 0Last Post: 08-08-2007, 04:56 AM -
help,t56 to 4l60e or 4l80e swap
By 00ls6camaro in forum General HelpReplies: 0Last Post: 06-11-2006, 11:33 AM
