Thread: injector size?
    Member Edward-T's Avatar
    Jun 2011
    N.C.
    Blue
    2002-WS6
    injector size?
    if i go with texas speed prc stage 2.5 heads which size injectors should i use?
    DFW
    '18 CTS-V
    '13 ZL1
    first, what other mods do you have? you don't necessarily upgrade injectors on a head only swap. your stockers would be enough. you are either 26 or 28 lb/hr stock.
    you will need to have the duty cycle checked out to determine whether or not you need injectors after the head install and tune. if your stockers flow 90% or higher in duty cycle its recommended that you go to larger injectors. 36lb/hr would suffice, but if you plan on doing major modding, go ahead and get 42lb/hr injectors and call it a day.
    Jun 2011
    N.C.
    Blue
    2002-WS6
    423 horse power and 396 FT. LB. Torque
    2005 LQ4 6.0 -64000 Miles at the moment
    6-speed Tremic transmission
    -Everything down has less than 5000 miles
    Texas speed Torquer V.2 Camshaft 595/598 lift 112 LBS
    Texas speed chromemoly pushrods
    Comp Cams Gold Double Beehive vavle springs good to a 660 lift
    Hedman Headers-
    Headman offroad Y-pipe
    Single Chamber Flowmaster Catback exaust
    4.10 Ring and pinion
    Eaton Positraction unit
    Spec stage 3 clutch (cevlar material)
    Race performer flywheel
    GM Heavy duty slave and clutch master cylinder
    Walboro Race 90 psi 255lph fuel pump
    New oil pump
    Professional DYNO tuned, tuned by JR Racing in Greenville South Carolina.
    LS6 Intake plentem
    Ported mass airflow
    ported throttle body
    Carbon fiber airlid
    polyuritane transmission mount
    Member jetaws6's Avatar
    Apr 2009
    Fallston, Maryland
    1998 Trans Am Ws6
    yea get some 42's your duty cycle is gonna be probably gonna be over 100% with the heads
    NC
    1998Z28
    I didn't have to change my stock injectors until I installed a Fast 90/90 setup. After that I went the Ford 42# but could have gotten by on 36# injectors. Since our fuel pressure is higher a 42# ford injectors equals out to be like a 50#er.
    TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
    Jun 2011
    N.C.
    Blue
    2002-WS6
    ok, thanks. any brand better than the other or does it matter really?
    NC
    1998Z28
    Quote Originally Posted by Edward-T View Post
    Everybody I know likes the Ford 42#s. You can usually pick up a set for $200 around our area.
    DFW
    '18 CTS-V
    '13 ZL1
    agreed, with your setup, get 42's. I'm running 42 with my set-up, and no worries about the duty cycle. the Ford's PFM mentioned are commonly referred to as 'green tops' since the top of the injector is green.
    for the life of me, i can't remember what brand mine are. regardless, no issues since installed. i chose to upgrade injectors when i decided to install and U/D pulley and EWP. my H/C/I/E were done and i was around 93% duty cycle. so for me, it was clear i needed to setup.
    EDIT: i'm running Lucas 42lb/hr injectors
  1. Injector Size
    By Track Junkie in forum Camaro / SS
    Last Post: 04-07-2014, 08:32 AM
  2. Injector size
    By skipjobe in forum LT1
    Last Post: 07-26-2007, 05:42 PM
  3. what size injector?
    By Soltakr in forum Nitrous
    Last Post: 07-20-2007, 06:07 PM
  4. injector size?????
    By ls1alltheway in forum External Engine
    Last Post: 03-23-2007, 10:10 AM
  5. HELP:How to identify injector size by pn
    By redz in forum Internal Engine
    Last Post: 01-08-2006, 11:38 AM
