Thread: Moser 9"
07-11-2011, 08:10 AM #1Impounded
- Apr 2010
- IN
Moser 9"
Found this on craigslist. Local listing.
My car is a DD and so i will have to get it to work with abs and parking break.
Moser 9" p/c black but has had lca relos and BMR arb brackets welded on after the rear was completed so they aren't coated at all, just cosmetics obviously. Rear is STOCK WIDTH, TRU-TRAC DIF, 4.11's with about 2000 miles on them and is Quiet! Nodular center, 31 spline and will come with backing plates but is not set up for abs or parking brake. All you will need is your T'bolts. Also has 1/2" studs.
How does this sound? Thoughts? Suggestions? Is it ok to buy used?
Someday id like to go procharger and/or nos abd maybe upgrade to 243 heads
07-11-2011, 08:22 AM #2Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
I bought my Moser 9" used, and my one word of advice is this: Get it rebuilt BEFORE you install it in the car...replace all the bearings (even if they look fine) and all of the seals. You'll thank me later.
2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
2000 Pontiac Grand Prix GTP: Twincharged w/ a T67 Turbocharger
2007 Chevrolet 3500 Dually Duramax: 3" Downpipe, Dual 4" Exhaust, EFILive Tuning
07-11-2011, 12:52 PM #3Impounded
- Apr 2010
- IN
Whats needed to make it abs and enable the parking brake?
07-11-2011, 01:51 PM #4
07-12-2011, 06:42 AM #5Impounded
- Apr 2010
- IN
Apparently there is a kit. Id just forget the Traction control. But te ebrake has to be removed from the stocker and pressed on the new(to me) rear, then the kit would refab it to make it work... So this basically makes it a waste of time...
07-12-2011, 01:49 PM #6
If you go to gm high tech performance and search moser 9" they have a really in-depth assembly and install to include abs and traction control.
07-12-2011, 03:45 PM #7Impounded
- Apr 2010
- IN
Apparently you cant put a 3channel on a 4 channel
Car so the idea is out. Thanks for the help tho
Used Moser 9"
By BashamWS6 in forum Suspension and HandlingReplies: 4Last Post: 02-16-2012, 04:08 AM -
Question: Moser 9", should I get 3.73 or 4.10
By WS6ICK in forum DrivetrainReplies: 11Last Post: 01-05-2009, 12:06 PM -
Moser 9"
By M-Ten in forum DrivetrainReplies: 4Last Post: 12-08-2007, 10:19 AM -
Moser 12 or the 9"?
By casper6871 in forum Suspension and HandlingReplies: 7Last Post: 08-15-2006, 05:33 AM -
Moser 9"
By BLO BY U - TA in forum Parts For Sale / TradeReplies: 0Last Post: 03-05-2006, 11:22 AM
