    Member jcws6's Avatar
    Western Pennsylvania
    2002 Trans Am WS6
    Question Strange Electrical Problem with Turn Signals
    We had a pretty big storm here a few weeks ago. Shortly thereafter (might've been a coincidence), I noticed that my turn signals weren't working. The arrow on the dash just stayed on, instead of flashing. So, I replaced the flasher module with one from Advanced Auto.
    Now, the arrows on the dash flash fine, and the taillights flash. But the front turn signal lights don't even come on. Neither turn signal position turns the lights on, and the hazards don't either. They aren't on as the DRLs, but both lights DO come on when I have the headlights up.
    What the hell?
    Jul 2011
    Chicago
    2000 WS-6
    I had a similar problem. My left turn indication didn't blink, it just stayed ON. This was caused by a bad Front left bulb. Upon inspection I found the bulb was still good, but there was a bad connection in the socket. The wires showed signs of a rough life; they were brown and overheated. I was going to repair/replace the connector but it started working after I had inspected it. So I think just inspecting the wires or pushing them in may help with an intermittant connection. I think thats what happened for me.
    Smasher
    2000 WS-6, NBM, BGRA, Clear Lid, Delphi MAF, Bobbit EGR, FLP Long Tubes, SLP Loudmouth, STB, SFC, EradiSpeed rotors, Fire Hawks, and lots of Zaino
    2002 Trans Am WS6
    My issue isn't intermittent. The lights never turn on unless the headlights are on.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    You might have a short in both front harnesses. I think the grounds for those wires are on the radiator core support. Inspect them and let us know what you find.
    Orlando, FL
    Mean Black
    agreed with all the above. Inspect the bulb sockets as well. They are prone to get corroded. You might need to clean them or replace them.
    Junior Member Jorgens's Avatar
    Jun 2011
    Sheboygan, Wisconsin, United S
    2002 Trans Am
    Also the flasher may be bad. I had a similar incident where I replaced the flasher. Right blinker worked, left did not. Thought bulbs, wires, who knows what. Turns out it was the flasher module, replaced that with a new one and returned the other "new" one to autozone and told the guy. he'd never heard of anything like it. but they all work fine now....
    Long story short, double check that flasher!!!!
    Orlando, FL
    Mean Black
    If the other turn signal flashes good is not the flasher. Both turn signals use the same flasher
    2002 Trans Am WS6
    I didn't get a chance to check the harnesses yet, but here's some more strange behavior:
    When the headlights are up, the front marker (turn signal) lights are on, as they should be. However, they won't flash when I hit the turn signal switch.
    Thoughts?
    Orlando, FL
    Mean Black
    Quote Originally Posted by jcws6 View Post
    Thoughts?
    Thsi could be something as simple as your bulbs are bad. There are 2 filaments in the bulbs. You need to pull out the sockets and inspect them including the bulbs.
    2002 Trans Am WS6
    Alright, that makes sense. I just replaced both f'ing bulbs last year. Dielectric grease & all. Even swapped a housing.
    Screw this, I'm going LED. I saw your thread about these (thanks, by the way) and realize that this is a lot better than cramming my hand inside the front bumper every year.
    Orlando, FL
    Mean Black
    the LEDs are a nice option. i went with those becuase my sockets were getting very hot and with time was messing them up. If you don't control the water/moisture issue even the LED will cause issues. Make sure the sockets are clean and in good shape but also inspect the housing for cracks. Look at the socket gasket and inspect them. If they look broke or rot you need to replace those. Apply dielectric grease like you did before. Autotrix sells a set of oversized gaskets that help to seal the sockets better.
    North Jersey
    2004 GTO M6
    I have also read about members using a drill with a small bit to make a hole in the turn signal housing to allow for condensation and heat to escape.
  1. problem with drl/ turn signals
    By 99pewterta in forum General Help
    Last Post: 08-09-2010, 07:58 PM
  2. Strange Electrical Problem
    By jcws6 in forum General Help
    Last Post: 11-08-2009, 06:18 PM
  3. Help: Strange electrical problem
    By GottaHaveLS1 in forum Stereo and Electronics
    Last Post: 08-20-2009, 07:49 AM
  4. Help: Strange electrical problem
    Last Post: 08-13-2009, 09:00 AM
  5. strange electrical problem
    By MCCs WS6 in forum General Help
    Last Post: 02-17-2008, 02:43 PM
