Thread: need advice
06-29-2011, 05:27 PM #1
- May 2011
- inglewood
black- 2000 camaro ss
need advice
i have a 2001 SS camaro n i want t know the best ways to improve my engine for speed
06-29-2011, 06:00 PM #2
Welcome!
Not sure what you mean -- 1/4 mile speed, high speed distance driving, autocross?
06-29-2011, 11:50 PM #3
- May 2011
- inglewood
1/4 mile
06-30-2011, 05:28 AM #4
First step is to beef up the suspension and driveline or you will simply be breaking parts. Not sure what you have done to your car, but the following are recommended:
1. Subframe connectors
2. Lower control arms
3. Panhard bar
4. Driveshaft safety loop
If you are running the stock 10 bolt, it won't last long if you are an M6 with sticky tires. An A4 car will not have as much driveline shock, so you may get away with running the 10 bolt for a while. Easiest engine mods are long tube headers, a lid with a quality non-oiled filter, a cooler thermostat, and a tune. Leave the MAF alone! After that, if you are an A4 car, a high stall torque converter is your best bet. Getting deeper into the engine, a cam is what can put you in the 11's with no other major engine work. Out back, 3.73 gears for an A4 and 4.11 gears for an M6 are the usual recommendations.
06-30-2011, 07:00 AM #5
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
^This. You may also want to look into a torque arm. The stock one mounts to the tail shaft of the tranny, and has been known to cause it to break. An aftermarket one will relocate it to the crossmember, or a tunnel mount. For drag applications, tunnel mount us usually prefered. It will transfer more noise, though.
I would also highly recommend the rear diff as well. Adding power and traction = bad results with a stock 10 bolt. Moser, MidWest Chassis, and Strange are some of the top choices for a good 12 bolt, 9 inch, or Dana 60.
06-30-2011, 08:39 AM #6
- Nov 1999
- over here...
what is your budget???
07-01-2011, 08:26 PM #7
- May 2011
- inglewood
no budget
07-01-2011, 10:37 PM #8
- Feb 2007
- San Diego, CA
Inglewood, Ca?
If you're an A4 a 3400 stall will shave ~.5 seconds off your quarter mile times. You may want to upgrade the tranny also.
As has been stated there are other things you might want to do that will improve the chassis (SFC's, adjustable tunnel mount TA, etc).
So what all is done now?67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
07-02-2011, 12:47 AM #9
No budget? You can easily start racking up $$ pretty quickly in these cars. I of all people know
New, need advice.
By tomscamaro00 in forum New Member IntroductionsReplies: 5Last Post: 04-05-2010, 06:26 PM -
Need advice, possibly legal advice
By JHayesLS1 in forum Almost Anything GoesReplies: 36Last Post: 12-19-2009, 09:23 AM -
Need serious advice...alot of advice. Long.
By !!!FAST!!! in forum Almost Anything GoesReplies: 0Last Post: 10-31-2007, 07:49 PM -
Hello, and need advice
By jpwamt in forum New Member IntroductionsReplies: 4Last Post: 12-19-2006, 07:18 PM -
Need ADVICE
By dblanch35 in forum Automatic TransmissionReplies: 1Last Post: 12-16-2006, 10:56 AM
