Results 1 to 20 of 22
Thread: Driving in rain
06-29-2011, 12:27 PM #1Junior Member
- Jun 2011
- Florida
Silver- 1999 Pontiac Trans Am
Driving in rain
Hello,
New to the forum and created this account to ask this question. I have a 1999 Trans am that has some modifications and a K&N filter on it. The problem is when driving in the rain the car has a terrible time running. It will spit and sputter and sometimes die out. It doesnt even have to be raining hard at all. Is it normal that these do this? or am I looking at a more serious problem?
Since I live in Florida and summer time is rolling around I really need to figure this out since it rains almost every afternoon.
Thanks for any feedback.
06-29-2011, 12:31 PM #2
doesnt sound normal unless the car is taking in water somehow,i have a debaffled hood and it rains here in ga. alot also and i dont have anything like that happening, so it only does this when its raining?
06-29-2011, 12:38 PM #3Spaz is My Mentor
do you have the cold air kit form slp? or like previous post a debaffled hood?
06-29-2011, 12:41 PM #4None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
It's not normal. Do you get any codes -SES light come on - when this happens? It could be a number of things. Water can affect many different componants. It's possible you may have water affecting the O2 sensor wiring, the spark plug wiring or coils, MAF wiring, ect. I would also get rid of the K&N filter and switch to a paper one. Pick up a can of CRC cleaner and clean the MAF too.
06-29-2011, 01:01 PM #5I Drive A 95'
- Aug 2009
- Granbury, Texas
01' Firebird Pewter- 98' Trans Am Black
check for water seeping inside of your coils and spark plugs and having it eat away at them, thats what happened to mine, 3 coils, and new plugs later, its all fixed
06-29-2011, 01:09 PM #6Junior Member
- Jun 2011
- Florida
I hate to say it but I have no idea what a debaffled hood is. But its not an SLP kit, it just has the Filter sitting out plain as day when you pop the hood open. And it has the regular firebird hood. Also my dad said before that he had the car running and swiped a wet paper towel over the filter and it started missing.
06-29-2011, 01:14 PM #7
06-29-2011, 01:24 PM #8Junior Member
- Jun 2011
- Florida
I will when I can but right now, to no surprise its raining. lol
06-29-2011, 01:27 PM #9
06-29-2011, 01:30 PM #10
judging by this comment "But its not an SLP kit, it just has the Filter sitting out plain as day when you pop the hood open." neither of them
06-29-2011, 01:34 PM #11
06-29-2011, 01:38 PM #12Spaz is My Mentor
jr shows a good point, if he has a stock hood the op should have something that looks like the 2 pics she posted. If not I highly doubt it is the Volant system (Twin filters)
Either way with a non ram air box he should have a lid of some type.
06-29-2011, 01:48 PM #13Exalted Cyclops
- Feb 2007
- San Diego, CA
If no box then he's probably sucking in water off of the front of the car through the nose...
One of my friends had this problem with his Z28 when it would rain. He had a ram air box (not SLP but similar) that went down the front of the radiator to catch cold air. Rain and it would suck up water, soak the filter and start sputtering.67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
06-29-2011, 01:50 PM #14
06-30-2011, 12:32 PM #15
07-01-2011, 03:58 AM #16
07-01-2011, 12:24 PM #17I need some money
- Feb 2007
- chandler az
hugger orange- 1999 camaro ss
Sounds like he has the kn fipk like what I have
Heres what it looks like
That's not mine by the way just a pic off the net
07-01-2011, 09:45 PM #18
Sound like water is getting in somewhere but even with an exposed k&n like about you should be fine in rain. A debaffled or gutted you could say. Cut out all the restriction so you can see my twin Volant though each openings and I have driven it in Houston in pouring rain though several inches of staning water and at high speed on the highway on rain has never affected my car. You.filter shouldn't let rain in if properly oiled and installed. I would check the filers and couplers for any leaks then other parts that people have stated about just start it and use a spray bottle to simulate light rain around each spot till you find the cause. Least that's how I would check I did that to my car to make.sure my.filters wouldn't let water in after cutting up the RAM air hood. Hell I even used a garben hose on low with a mist spray just to be sure after the spray bottle but sounds like your car is sensitive enough to react to just a spray bottle.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
07-02-2011, 01:33 AM #19
Sucking up water into the intake is not good and if it's happened to anyone in this thread, I'd be looking at getting that fixed ASAP.
07-02-2011, 06:28 PM #20Junior Member
- Jun 2011
- Florida
Sorry for not replying in a while guys.
This looks exactly like what I have.
And from what im gathering I need a new induction system. Or I could just build some kind of plate that i can slide infront the filter for when it rains.
Thanks for all the help guys. Allot better than most forums.
Ram Air and Rain
By LeadFarmer in forum External EngineReplies: 40Last Post: 10-10-2012, 09:13 PM -
Rain Rain go away !
By redls1 in forum Almost Anything GoesReplies: 60Last Post: 10-14-2009, 12:43 PM -
F1 in the rain??
By snaggeltooth in forum Almost Anything GoesReplies: 6Last Post: 05-25-2008, 01:18 PM -
Why does it rain??
By JoshieDoom in forum Almost Anything GoesReplies: 6Last Post: 03-28-2008, 08:28 PM -
got wet in the rain
By bulljock in forum External EngineReplies: 4Last Post: 10-24-2007, 07:42 AM
