Thread: What's best cure for wheel hop?
06-28-2011, 09:44 AM #1
- Sep 2005
- Waukesha, WI
Hugger Orange- 1999 Camaro Z28
1999 Camaro Z28 - M6. Suspension-wise, I've got sub-frame connectors, SLP Panhard and Lower Control arms. The car is making about 350hp at the tires and I've got an Centerforce Clutch and 3.73 rear end gears.
Here's my glitch, I snapped the driveshaft while launching hard (4000rpm) on a pretty sticky track using drag radials. It really felt as though the rear end hopped around a split second before the shaft broke. I had been feeling some wheel hop around town on street tires before, but she really jumped at the track.
I bought a new BMR torque arm (one that attaches to the trans tunnel brace) and am planning to put it in this weekend. The transmission mount on the stock torque arm feels pretty mushy, but is otherwise undamaged.
Before heading back to the track, I need to build up my confidence that I won't be breaking my new drive shaft (got an upgraded cro-moly one from Speed Inc). Thanks!
06-28-2011, 04:11 PM #2
- Jan 2009
- North Jersey
Try BMRs drag bags.
06-28-2011, 05:46 PM #3
- Jun 2008
- Euclid,ohio
Black- 1998 Z28
LCA relocation brackets and aftermarket shocks.
06-28-2011, 05:48 PM #4
- Sep 2006
- Canby, Oregon
Pewter- 1999 Camaro SS-M6 #1775
LCA's and new shocks took away my wheel hop
06-29-2011, 08:37 AM #5
- Sep 2005
- Waukesha, WI
Being the overkill guy that I am, I did get a set of LCA relocation brackets as well. But I figured I should do the torque arm, do some testing, and later do the LCA backets. Maybe I'll make an exception this time and do them both together. I'm probably entering the "stupid zone"...
06-29-2011, 08:38 AM #6
- Sep 2005
- Waukesha, WI
Oh, yeah. What kind of shock are you guys using? Something drag specific, adjustable or just a good everyday set of shock?
06-29-2011, 09:34 AM #7
- Feb 2007
- San Diego, CA
Is the new torque arm adjustable? An adjustable TA set with the pinion ~2 deg down cured my wheel hop problems. I also went with the tunnel mount (short) type as it allayed my fears of breaking the tranny tailshaft and it had a DSL.
67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
06-30-2011, 09:30 AM #8
- Sep 2005
- Waukesha, WI
Thanks for the advice 67Camaro!
I did get an adjustable one as well as a magnetic angle checker tool. I guess I can play with the angle...
I have a fever and the only cure is a corvette
By 1998 T/A in forum Firebird / WS6Replies: 13Last Post: 08-08-2015, 06:11 PM -
Best hangover cure
By Sarge in forum Almost Anything GoesReplies: 59Last Post: 01-03-2011, 06:25 AM -
Cure for the mid-life crisis
By razer900 in forum New Member IntroductionsReplies: 17Last Post: 05-25-2009, 06:14 PM -
How to cure backfire?
By Wheeler99WS6 in forum General HelpReplies: 14Last Post: 10-20-2006, 11:41 AM -
Praying's No Cure For Sickness
By BillyT in forum Political / Debate ForumReplies: 22Last Post: 04-07-2006, 05:55 AM
