    Army Dude robcas47's Avatar
    Ft. Rucker Area, Lower AL
    01 TA / 06 Duc 749D
    Key Fob programing
    Anyone know how to program a key fob to an 01 Seirra? I tried the same method as my TA requires but no luck.
    I searched around the net and found this, might try it:
    1. Get in truck and close all doors
    2. Put key in ignition
    3. Press and hold the door unlock switch
    4. While holding door unlock swich, cycle ignition 2 times, ON-OFF-ON-OFF
    5. Release the door unlock switch, the door locks should lock and unlock to confirm the programming mode
    6. Press and hold the LOCK and UNLOCK buttons simultaneously on one transmitter. After a delay of approximately 15 seconds the doors will lock and unlock to confirm the programming of that transmitter
    7. Repeat step 6 for each additional transmitter (up to 4), including any you had before.
    8. Turn key to RUN to exit programming mode.
    9. Operate the transmitter functions to ensure correct system operation.
    I found the same on gm-trucks.com
    That was where I found it
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    Quote Originally Posted by GM Tech Manual View Post
    Transmitter Programming
    Important
    All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
    You may program up to 4 transmitters, using either of the two following procedures:
    Transmitter Programming Procedure (Method 1 - No Tools Required)
    Close all the vehicle doors.
    Insert the ignition key into the ignition lock cylinder.
    Press and hold the door unlock switch.
    While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
    Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
    Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
    Repeat the previous step to program up to four transmitters.
    Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
    Operate the transmitter functions in order to verify correct system operation
    You MUST program all remotes at the same time. Programming one new remote will change the code causing any existing remotes to no longer work.
    Try this.....
    01 TA / 06 Duc 749D
    Will try here in a minute. thanks Y2KPewter
    This worked, thanks again.
  1. O2 Sensors Programing
    By toenale56 in forum Computer & Tuning
    Last Post: 05-06-2010, 10:28 AM
  2. Direct Tv programing ?
    By redls1 in forum Almost Anything Goes
    Last Post: 04-06-2010, 12:42 PM
  3. Programing our Vehicle's
    By FORMULA7 in forum Computer & Tuning
    Last Post: 09-15-2006, 07:01 PM
  4. Programing LS6
    By Footloose in forum Computer & Tuning
    Last Post: 06-15-2006, 01:44 PM
  5. Programing Keyless Entry
    By GOAT6SPD in forum Western Members
    Last Post: 09-07-2005, 02:48 PM
