Results 1 to 10 of 10
    May 2008
    delete me too
    Long time before oil change, advice?
    Ok, so I drive my T/A about 30 x a year?, and the deal is that I drove only about 2000-2500 miles, but it was in about a 1.5- 2 year range. I'd like to hear from some oil gurus on this as to whether it is something that desperately needs changed immediately or if I am ok. The engine is modified, so the piston ring clearance is not as tight as oem, so that is my concern... oil breakdown due to blow-by, etc. I know i'll get a lot of crap for this, but it just seemed ridiculous to change it after a year when i drove the car only about 1000 miles. Some advice/helpful comments would be great!
    CLASSIFIED
    NBM Z28
    2002
    I would like to hear as well. I also hardly ever drive my car. I try to change my oil every 4k miles, but i hardly ever drive it to even reach 4k miles. So now, i will just change it once a year.
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    You should change the oil at least once a year.
    Orlando, FL
    Mean Black
    Agree with Cutlass change it once a year.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Use a synthetic oil, the condensation that occurs from the vehicle sitting will stay on top of the oil, rather than diluting (sp) it, as in the case of conventional oil.
    My vehicle 01 Z28 has 28K original miles (purchased 12/00), I use synthetic oil, and change it (and the oil filter) every 1 to 1 1/2 years. The oil removed is still very clean.
    SteveC
    Senior Member Z28_Driver's Avatar
    Jun 2009
    Ohio
    Sunset Orange Metallic
    2002 Z28 Hardtop
    Just to be on the safe side you should change it once a year. It doesn't cost that much for the peace of mind it gets you.
    May 2008
    delete me too
    Alright, but does anyone know if this would have done any kind of extra damage to the engine? Or is it simply not recommended?
    Jul 2009
    North of the Motorcity
    Custom Swirly Black
    2001 WS6 M6
    Quote Originally Posted by hot93rod View Post
    Moisture can build up inside and mix with the oil, especially if it sits for the winter. I always change my fluid(s) before winter/after winter.
    It's pretty much recommended thing, most fluids have a expiration time on them b/c they can begin to break down. Especially coolant.
    Mike The Guz's Avatar
    Lawndale, CA
    Artic White
    2002 Camaro SS
    I change mine out once a year with it sitting in the garage.
    2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
    Jun 2009
    Ohio
    2002 Z28 Hardtop
    As water condenses in the crankcase over time it dilutes the oil. Water diluted oil does not lubricate as well as straight oil. More wear in the engine will be the result.
  1. Need serious advice...alot of advice. Long.
    By !!!FAST!!! in forum Almost Anything Goes
    Last Post: 10-31-2007, 07:49 PM
