03-25-2006, 06:22 AM #1Member
- Jan 2006
- Vienna WV
Silver- 98 Trans Am
Anyone ever make a speaker baffle panel in place of the rear cargo panel?
I was thinking you could put a couple 6x9s or something back were the cargo cover panel is. Like make your own out of mdf, and cover it, might also make small enclosure attached to back side. It would sound better than the rear speaker that are already there. Or would this be to close to the stored t tops?
03-25-2006, 10:25 AM #2Rock-n-Roller
- Jul 2005
- OHIO Go Buckeyes!
Arctic White- '07 Trailblazer LT
You need a panel with a LOT more mass than that if you want to mount a full range speaker there. Otherwise you'll get vibrations/rattles out the ying yang. You can't just go and place something as heavy as a full range speaker in something as flimsy as the rear hatch cargo cover and expect it to sound good. It may add more highs to the overall sound but the bass will be very weak due to the flimsy panel.
03-25-2006, 12:52 PM #3
i put 5x7s in there, that is as big as i would go though.
03-25-2006, 01:53 PM #4Detailing + Design
- Pittsburgh, PA
i think you should try a set of 4" full ranges. they will do just fine. your sail panels should suffice the bass. If not, get a sub.
03-26-2006, 10:29 AM #5Member
- Jan 2006
- Vienna WV
Silver- 98 Trans Am
I wasnt talking about the stock cover I said make a new one out of mdf or something I would never hack up the stock one.
Originally Posted by White Rascal
03-26-2006, 02:41 PM #6
Should work or you could make it flip up for t top use like the box I have. You should be able to add some sound deadening to the rear panels where the speakers are now and enclose them, would be much easier. I covered my panels in the hatch and took away road noise and there is plenty of room to work with there.
04-02-2006, 10:44 AM #7Member
- Jan 2006
- Vienna WV
Silver- 98 Trans Am
That looks pretty slick! Whats the main cover made of 1/2 3/4?
04-02-2006, 09:10 PM #8
subthump used to sell them for 2, 10 inch subs(think it is 1/2 inch), not sure if it is mdf or not, is pretty solid, the box itself attached to it is mdf, and flips up if I use the T tops and easily removed for the track. It has a set of metal pieces and sits in the place the stock cover in the hatch goes(works just like the stock one). I have taken the panels off in the hatch and that would be the best place to add some speakers if you want them in the hatch. Right now I am running 4 infiity 62.7i's, 1 in each door and 1 in each sailpanel, then I ran the speaker wires from the hatch to the tweeter in the sailpanel to give me highs. I don't miss the hatch speakers not being there at all. You could easily fit a 6x8 in the stock 4inch speaker location and add some sound deadening. I made a enclosure behind the 4inch speakers I had in there out of wire and sound deadening, worked good and was light weight, but now I don't use any speakers back there.
Question: Rear seat speaker panel removal.
By speedyWS6 in forum Firebird / WS6Replies: 65Last Post: 07-15-2015, 04:59 AM -
rear seat speaker panel help
By Ramairgod84 in forum General HelpReplies: 7Last Post: 12-16-2009, 01:32 PM -
For Sale: Alpine Reciever,Door And Rear Panel Speaker 4 Sale
By Dillard99 in forum Parts For Sale / TradeReplies: 1Last Post: 09-14-2008, 01:29 PM -
rear speaker panel
By txman4362 in forum Stereo and ElectronicsReplies: 1Last Post: 06-05-2008, 08:26 AM -
Tail panel black 2001 SS and a plastic interior hatch panel that covers the speaker
By pbjones81 in forum Parts For Sale / TradeReplies: 0Last Post: 12-07-2006, 01:20 AM
