Thread: Exhaust bung (sp?)
06-19-2011, 08:49 AM #1
Exhaust bung (sp?)
I bought an air/fuel ratio gauge and have a couple install questions. This a photo of the exhaust bung. It appears that it is just welded on. Shouldn't it be drilled out? If so, I guess the shavings won't damage the catalytic converter? Also, should i use some type anti-sieze on the threads? It seems to have something on it now. thanks
06-19-2011, 01:34 PM #2
Did you try and wrench it off? It looks like a plug. And not factory. And yes, use anti seize.
06-19-2011, 02:48 PM #3
Agree. That looks like it may be a plug. The angle is wrong to really tell from the pic though. Is it located before or after the converter? An A/F gauge sending unit needs to be installed upstream of the converter to work properly.
06-20-2011, 04:25 AM #4
You're right. It was a plug. Makes me feel pretty stupid. It is located ahead of the cats. Got it installed yesterday and its working correctly. Thanks for the help.
Exhaust Bung Spacer
By pajeff02 in forum Computer & TuningReplies: 15Last Post: 11-02-2011, 04:05 AM -
bung placement for wide band 02
By qwik219d9 in forum Computer & TuningReplies: 7Last Post: 06-18-2010, 08:50 AM -
where to install o2 bung
By Z28boy2000 in forum External EngineReplies: 3Last Post: 10-11-2009, 05:53 PM -
cost to weld a bung on ?
By Danger731 in forum General HelpReplies: 11Last Post: 04-08-2008, 08:47 AM -
For Sale: New o2 bung & plug
By MagicMan in forum Parts For Sale / TradeReplies: 3Last Post: 03-20-2008, 06:34 PM
