Thread: Pushrod Issue
06-16-2011, 08:32 PM #1
Pushrod Issue
installing a new cam today and after removing the pushrods i came across this problem on almost each one in varying degrees of severity...
i had some po-dunk shop install my head/cam a while back and it seems like everything they did the botched it up
how did this happen and what can i do to make sure nothing like this happens in the future?
any advice is appreciated.
06-19-2011, 02:45 AM #2Senior Member
- Apr 2008
- Madison, WI
pic is kinda small and dark. What exactly happened to that pushrod?
06-22-2011, 07:52 PM #3Mustang Eater
- Feb 2010
- Springfield, Missouri, United
Maroon- 2000 z28 6 speed
cant really tell with that little picture...
2001 B4C Totaled 4/25/11
2000 Z28 M6 Cammed N' Slammed (SVT KLR)
06-22-2011, 09:01 PM #4
06-22-2011, 09:03 PM #5
Here, maybe this will help some..
06-22-2011, 09:17 PM #6
Interesting. I've never seen anything like that before. Subscribed.
06-22-2011, 09:25 PM #7Exalted Cyclops
- Feb 2007
- San Diego, CA
An anecdote:
Back in the day (late 70's - before I knew what I was doing) I set up a set of SBC 461 heads to run screw in studs and guide plates. I didn't have the push rods guides in the head drilled out (like I said - didn't know much) and I didn't run hardened push rods. I had the same effect as you, i.e., I watched (had clips on the rockers to prevent oil from spouting out everywhere) as a new set of pushrods were ground down to dust where they rubbed against the guide plates.
Any of this sound familar?
P.S.: Yeah, I learned a lot of shit the HARD way...67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
Carbon footprint? CLOWN SHOE!
06-23-2011, 07:56 AM #8Mustang Eater
- Feb 2010
Oh i see that now, i have no idea! looks almost machined into it. Subscribed.
pvc issue... vacuum leak....tune issue?
By okiels1 in forum General HelpReplies: 3Last Post: 03-05-2016, 09:10 AM -
Help: Bent Pushrod
By cowstandmoto in forum Firebird / WS6Replies: 27Last Post: 06-06-2013, 03:49 PM -
pushrod length??
By Mikat1 in forum Internal EngineReplies: 1Last Post: 03-15-2011, 09:36 AM -
bent pushrod issue
By natews6 in forum Internal EngineReplies: 14Last Post: 06-15-2010, 09:09 PM -
Help: I think i have a bent pushrod!
By camaroluvr447 in forum General HelpReplies: 21Last Post: 12-24-2009, 10:18 AM
