Results 1 to 20 of 27
    Jun 2011
    nebraska
    2010 sprint car
    heads and cam swap and no hp gains
    I have a 2002 camaro motor with a 4l60e tranny. I recently installed a set of 215cc AFR heads with a 59cc chamber and a G5x4 cam from LG motor sports and after tuning it with HP tuners on the chassis dyno I was only able to get about 360hp at the rear wheels. We've checked everything I know of and we're still about 100 hp down. Any ideas or thoughts would be helpful.
    Jun 2011
    Western Australia
    British racing green
    01 vx hsv gts c4b
    Is the auto good is it being strapped down properly what other mods did you do it may not be breathing properly or running out of juice
    Member jsmith564`'s Avatar
    Apr 2009
    covington ga
    yellow
    2004 gto
    i was also thinking fuel...
    Senior Member Z28_Driver's Avatar
    Jun 2009
    Ohio
    Sunset Orange Metallic
    2002 Z28 Hardtop
    Most likely fueling problem. Could also be exhaust and intake if not the fueling issue.
    Jun 2011
    nebraska
    2010 sprint car
    I have a trick flow fuel regulator that is set at 60psi. One of the guys there watched the fuel gauge during one of the pulls and said the pressure didn't drop. I'm running headers, an underdrive pulley, and that's it for mods. Wouldn't we see it on the HP tuner if I was running out of fuel? I'm using the stock injectors, the guy that dynoed the car said I had plenty of fuel, but I've been wondering if that could be the problem myself. Any suggestions on how to determine if I have enough fuel? That motor has the LS6 intake, we did a smoke check for vacuum leaks and didn't find anything for leaks. We did a pull in 2nd gear to see if that changed anything and the #'s were the same. We changed tire sizes and the #'S were the same. After all of the dyno time we did a leak down on the cylinders and they were all less than 5%.
    I appreciate the help, Thanks
    Jun 2011
    nebraska
    2010 sprint car
    Has anyone heard of lifters going bad? Is it possible that I'm not getting the lift that the cam is giving me?
    NC
    1998Z28
    Is your throttle body opening up all the way when you press the pedal to the floor?
    Jun 2011
    nebraska
    2010 sprint car
    Yes. we actually pulled off the MAF and filter for a pull to watch it.
    When I installed the cam, I didn't degree it in, I was told by LG just to line up the dots and it will be fine. Could that be the problem?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Lifters either usually get stuck or collapse. I don't think that's your issue though.
    As far as injector sizing, that is a straight up formula.
    Assuming you use a BSFC of 0.5 (non turbo or SC car), use a base HP of say 450, and a duty cycle on your injectors of no more than 80%....
    Your approximate injector size would be about 35 lbs/hr, which would mean your stock 28-lb injectors are inadequate.
    Were any other cars DYNO'd that day?
    Jun 2011
    nebraska
    2010 sprint car
    No there weren't any other cars on the dyno that day.
    I was told that stock injectors are fine by LG. So that's what I tried, I do have a set of 42# injectors I could try to see the difference when I get it back together.
    Another thought, I didn't have my cam degreed when I put it in, I just put it in dot to dot. Could the cam be far enough off that it would cause some problems?
    Member 666ws6's Avatar
    Greenville, SC
    2000 Trans Am Ws6 #2946
    With HP you can tell if your injectors are being maxed out or not, so don't just change them yet. Get back on the dyno and check those first. Hopefully they do that free of charge, but likely not.
    Feb 2006
    MD
    What does the dyno graph look like? HP should be peaking around 6500rpm, and torque just under 5000rpm (converter dependant). What rockers are you using? Finally, and most importantly, are you SURE it's not running on 7 cylinders?
    Jun 2009
    Ohio
    2002 Z28 Hardtop
    Quote Originally Posted by adamwackel View Post
    Probably not lifters. You would hear that problem.
    Whatever you do, you definitely don't want your injectors "max'd" out. 80% max duty cycle.
    May 2011
    som
    2002 b4c
    no wideband at the dyno?????/
    Quote Originally Posted by Z28_Driver View Post
    My dyno guy always gives me air fuel ratio with the wide band in the pipe. i don't see how you could tune without it. That's how you rule out a fuel issue.
    Jun 2011
    Western Australia
    01 vx hsv gts c4b
    I know guys do the dot the dot and it works but I always dial it to the card to make sure it's what you paid for
    It sounds strange no power I would've thought you pick up a little then tune for more bit tuned and no gain maybe try another tuner
    bc
    How does it feel compared to the old setup?
    What type of dyno?
    I recently finished up my car and during the tuning process I was having misfires and the car was not running properly at low idle.
    I'm using 63-lb Simein injectors for my set-up. After much diagnosis, and returning everything almost back to stock to eliminate everything that could be a cause, we found that it was the spark plugs we were using. We swapped the Autolite's out with some NGK's and voila. Car ended up making 540rwhp on 8lbs of boost.
    I had great fuel pressure the entire time ~ 60psi.
    phoenix
    04 2500 4x4 crew cab
    540 sounds nice.
    Jun 2009
    Ohio
    2002 Z28 Hardtop
    Quote Originally Posted by the71ub4cm30 View Post
    Obviously there was a problem somewhere in the process. You might have found it. You don't have to know what your doing to open a hotrod shop.
  1. Gains from LS6 Head Swap
    By TheGimp711 in forum Internal Engine
    Last Post: 02-29-2008, 11:24 AM
  2. HP gains from polishing heads
    By FuriousGeorge in forum Internal Engine
    Last Post: 11-15-2007, 06:05 AM
  3. post your before/after converter swap gains here
    By silverz28camaro in forum Drag Racing
    Last Post: 08-21-2007, 09:56 PM
  4. Gains w/Heads..
    By tyxpx in forum External Engine
    Last Post: 08-17-2007, 06:37 AM
  5. gear swap gains?
    By silverz28camaro in forum GM Trucks
    Last Post: 07-13-2007, 12:02 PM
