Thread: Cam question
06-13-2011, 02:01 PM #1
- Mar 2010
- St Pete, FL
Bat mobile black- 2000 Trans am WS6 M6
Cam question
Just wondering how much hp would i typically gain just from swapping a cam that had a higher lift. Say i have the TSP 233/239 camshaft with a lift of .595/.603 and i swapped it to a cam that was basically identical in duration but had a lift of say .640/.605. Would it be worth the trouble or what exactly is everyones opinions on this?
06-15-2011, 10:17 AM #2
You would really only notice gains if your heads and intake could flow more at that high a lift.....might be 20hp, might be 0 if your heads or intake are already maxing out.....but if I'm right it would give you more torque in the lower rpm range and then permit better scavaging in the higher rpms
06-15-2011, 11:19 AM #3
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
^This. It would be the most beneficial to do a h/c/i swap all together. But, you can throw it in now, and support it later.
06-15-2011, 12:21 PM #4
The first thing you better do if your going to 600+ lift is get some new valvesprings.
You might also want to check if a cam that size will cause piston/valve interference.
Some new pushrods would be a smart choice as well.
With a cam that size you will sacrifice low end torque for high end rpm.
If its mainly a street car with ocasional track use you may want to go smaller like the first cam you listed.
That one looks like it would be a better choice.
06-15-2011, 03:19 PM #5
- Mar 2006
- CLASSIFIED
NBM Z28- 2002
I honestly dont think it is worth the swap at all. You have a good size cam. I actually thought about stepping up to a cam that size. But to swap out a cam just for the lift i dont think is worth it.
06-15-2011, 07:44 PM #6
- Mar 2010
- St Pete, FL
ok it was just a hypothetical question. I understand you can only make so much power if your air intake is limited. Everything else aside that you would think of like the heads, and intake. Cam vs Cam.
06-16-2011, 04:26 AM #7
- Mar 2006
- CLASSIFIED
NBM Z28- 2002
06-16-2011, 04:47 AM #8
lift on its own after 600 does not help any on my heads.. mt flow sheet is like 319 @500 lift at 600 its 320 and at open its only 322.
not thats not my numbers but that how it goes. im only running a 2.02 valve on a dart head.
other heads with bigger valves may differ but i dont think ull see much after 600 lift. not worth the wear and tear on the valve springs.
im running comp cams hr281 thats 228/230 with 571 and 573 lift and a 112 lsa.
its a high rpm can on stock heads it felt like a on off switch at like 5500Last edited by blackbirdbrain89; 06-16-2011 at 04:50 AM.
06-16-2011, 06:27 AM #9
- Mar 2007
- NC
NBM- 1998Z28
Well when people change their rocker arms to a 1.85 ratio thats the same thing as added lift and they say 15-20 hp gains. But alot of cams won't gain that power and the cam info will tell you not to use the 1.85 ratios. so I'd say its hit and miss.
TSP 347 SB, TSP Stage 2.5 PRC LS6, TSP MS4, Performabuilt Stage 2 4L60E, Yank PT4000, 4.11s, Fast 90/90, FTRA Cold air intake+all the free mods, Dynatech Supermaxx Exaust System, DMH Cutouts, Hooker Catback/FTRA Tips. Tuned by RPM/Garner NC. 11.28@119
speedometer question + top speed question
By Krazy351w in forum General HelpReplies: 7Last Post: 06-21-2007, 05:51 PM -
HPIII question (not the same old question)
By slims00ls1z28 in forum Computer & TuningReplies: 5Last Post: 06-01-2007, 04:55 PM -
97 Bird Headlight question also engine noise question
By Zapper2003 in forum General HelpReplies: 2Last Post: 12-13-2006, 03:03 AM -
Speedometer question, RPO question
By acrylicophobia in forum Firebird / WS6Replies: 12Last Post: 11-02-2006, 07:08 AM -
Sex Question spinoff- PORN QUESTION
By egaian in forum Almost Anything GoesReplies: 77Last Post: 07-26-2006, 03:07 PM
