Page 1 of 4 1234 LastLast
Results 1 to 20 of 62
    Jun 2011
    illinois
    2002 ws6
    please help code p0102
    after getting my pcm back from tuned by frost hoping it would fix my problem and after 10 minutes of drving the problem is back. ses light came back on so i had it scanned at auto zone p0102 which said: mass or volume air flow circuit low imput probable cause
    1. poor electrical connection
    2. vaccum leak on engine
    3. dirty or blocked air cleaner
    4. Faulty MAF or TPS
    i sent my pcm in for my header and ory y pipe no cat and air pump delete. my 02 has vaccum lines along the firewall. the line goes into a sensor and another line comes out of the sensor and into the air pump since i removed the air pump i stuck a screw in the line out of sensor. and removed the air fuse. i also cleaned my maff sensor with rubbing alcohol. still the problem is after driving for 10 minutes or so the car will cut in and out and will go away if i romp on it. also lots of black soot coming out exhaust. PLEASE HELP! i am lost, thanks in advance
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Would you like me to combine this thread with your other thread?
    Jun 2011
    illinois
    2002 ws6
    please do you are alot of help 35th, im just a noob
    Actually I can't because I'm not a moderator in this section
    Anyway, I responded in your other thread
    Jun 2011
    illinois
    2002 ws6
    can anyone help me out?
    Did you clean your MAF with CRC?
    You have about 3 different threads now with people giving advice in each one. If you don't do anything anyone is recommending, how do you expect to fix the issue exactly?
    Jun 2011
    illinois
    2002 ws6
    i have 2 threads i cleaned the maf with crc cleaner like you said and still runs like shit what vaccum lines do i check?
    Senior Member
    Jacksonville, FL
    Haven't seen your other threads yet, but I'd check the ENG SEN fuse for an open. The MAF, 02's (and a couple other things) are on the same circuit if you have a M6.
    Jun 2011
    illinois
    2002 ws6
    check the engine service soon to see if it is blown?
    Jun 2011
    illinois
    2002 ws6
    blown ses light fuse i meant
    Senior Member
    Jacksonville, FL
    Fuse labeled ENG SEN (engine sensor) under the hood. Something easy to check. It can blow if an 02 wire shorts on a header, throwing P0102.
    Jun 2011
    illinois
    2002 ws6
    YES! the ses eng fuse was blown, i replaced with a new fuse started it ran bad ses light still on and tons of black soot coming out of exhaust.
    Senior Member
    Jacksonville, FL
    Get under the car and check the 02 harnesses for a burnt spot where it was arcing against a header, my guess would be on the passenger side.
    Jun 2011
    illinois
    2002 ws6
    ok thanks alot guys, so i checked the wires they werent melted. i took the front 2 o2 sensors out and cleaned them off put them back in and tightened a vaccum line behind the intake. drove it for a half hour and had full power back. the ses light stayed off.
    the only minor problem now is it still stutters when cruising and not giving it alot of gas.
    is it possible my maff sensor is shot?
    my ses light is not on though
    Jun 2011
    illinois
    2002 ws6
    could my fuel filter be dirty? what is the symptoms of that
    Senior Member
    Jacksonville, FL
    Drive it a while and see what happens - there's a reason it threw P0102 - surprised SES turned off so quickly by itself without clearing the code(s)? Is your car a M6? Skip shift and reverse lockout are on the same circuit. Doubt it's the fuel filter...still thinking 02.
    Jun 2011
    illinois
    2002 ws6
    it has skip shift but it was tuned out, also have the skip shift eliminator plugged in. i did unplug the battery when working on it so that reset the ses light but it never came back on. not sure if it is a m6 it is a 2002 ws6 6 speed ls.
    Senior Member
    Jacksonville, FL
    OK, disconnecting the battery might have reset it. Since you have a M6 (six speed car) if the fuse blows again you will be able to tell - it'll be hard to get into reverse. Put some miles on it. Disconnecting the battery probably reset the PCM. Most codes don't illuminate the SES light until three consecutive failures.
    Jun 2011
    illinois
    2002 ws6
    yes it is hard to get into reverse, why is this? and when the fuse blows what would cause it?
    Senior Member
    Jacksonville, FL
    Reason it's hard to get into reverse when the fuse blows is because the reverse lockout solenoid is on the same circuit. If it just happened check the ENG SEN fuse again. If it's blown you still have a short.
  1. Help!!! P0102 code!!!!
    By mjs0808 in forum General Help
    Last Post: 10-09-2012, 07:32 PM
  2. P0102 & p0122
    By shady milkman in forum General Help
    Last Post: 06-29-2010, 07:25 PM
  3. p0102 mass air sens cir low freq ?????
    By JRENIGAR in forum General Help
    Last Post: 05-04-2010, 04:29 PM
  4. Help: P0103 and P0102
    By SandmanWs7 in forum General Help
    Last Post: 05-03-2010, 07:44 PM
  5. Trouble codes p0171 p0102 p1153
    By redbird555 in forum Computer & Tuning
    Last Post: 02-24-2010, 06:23 PM
