Results 1 to 11 of 11
Thread: 228r cam?
06-08-2011, 08:36 PM #1
- Mar 2011
- elko, Minnesota
- 2002 z28 silver m6
228r cam?
never done any sorts of cam work but ive done some research and wanted to see what you guys thought of this set up
02 z m6
228/228 .588, 112 lsa, tungsten pushrods, .600 lift valve springs, ported ls6 oil pump, ls2 timing chain, headers and a tune?
was also wondering if the timing chain upgrade is needed? and or if you have any suggestions thanks!
06-09-2011, 09:41 AM #2
yes get the LS2 timing chain.
06-09-2011, 09:49 AM #3
i would go .650" lift (dual) valve springs...IE: Patriot Dual Gold Valve Springs .650" lift.
you should be fine at the stock pushrod length of 7.4", but double check. im running a 224 single pattern cam, same lift (.588), same LSA (112) and im running Comp Poly 7.4" PRs.
the 228 is a proven under the curve cam, with good tuning and street manners. you will be pleased
06-09-2011, 09:51 AM #4
definitely get .650 springs. I run this cam with 243 heads with a 7.4 pushrod.
06-09-2011, 10:07 AM #5
- Mar 2011
- elko, Minnesota
ya i wasnt sure with the lift raiting on those springs, what kind of power you guys throwing down? ive heard of up too 400 with out heads...
06-09-2011, 10:49 AM #6
I put down 418 with patriot 243's and a fast 102. I need a bigger cam for my set up (which I am looking into) but I think your gonna be in the 380 area with out heads.
06-09-2011, 12:49 PM #7
06-09-2011, 12:58 PM #8
Running the same cam on 112 LSA and love it
06-09-2011, 06:53 PM #9
- Mar 2011
- elko, Minnesota
one last question can you run the stock ls1 timing gears with the ls2 timing chain?
thanks for all the replies
06-10-2011, 04:08 AM #10
06-10-2011, 04:33 AM #11
my 228R
By ls1wallen in forum Multimedia SectionReplies: 6Last Post: 03-30-2011, 07:57 PM -
228r cam and slp lid
By silverWS6 in forum Parts For Sale / TradeReplies: 34Last Post: 08-23-2010, 06:54 PM -
228r cam
By ChevyLS1 in forum Camaro / SSReplies: 30Last Post: 07-13-2010, 10:19 AM -
228R cam
By jmatt07 in forum Internal EngineReplies: 7Last Post: 01-31-2009, 12:57 PM -
Tsp 228r
By TheKitchenSink in forum Internal EngineReplies: 5Last Post: 09-22-2006, 03:04 PM
