Results 1 to 20 of 27
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    Billet specialties street lite backspace question
    Hi guys I'm planning on going with billet specialties street lites on my car in the near future 17x7 out front and 17x11 out back question is what size backspace do I need for the back I've seen 7.75 and 7.5 both used the 7.5 does stick out from the fender a little bit though which I kinda like the look of. The 7.75 wheel is a custom wheel and costs about 100 per wheel more than the 7.5. Since the 7.5 is cheaper and IMO looks a little better does anyone know if it would hit the fenders on large bumps since it sticks out or would it hit the bumpstop before that happened? And if for whatever reason it did hit the fender could I just bolt a spacer on the bumpstop to make it hit before the tire hit the fender?
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    If you go with a lower aspect ratio/profile in the rear, you MIGHT rub going over bumps. MIGHT.
    Mar 2009
    well with 17x11 wheels im kind of limited on tire sizes. but aside from that I'm not sure i undertsnad what your saying. Your saying with a lower aspect ratio, ie a shorter tire I might rub? I think in the morning I'm going to measure the distance from the bump stop to the axle worse comes to worse couldnt I just use a spacer to put the bumpstop closer to the axle thus decreasing suspension travel and making it bottom out before the tire could hit the fender. I mean when you lower the car 7 your essentially doing the same thing its just your also adding stiffer shocks usually to help.
    Coral Springs, Fl
    Sunset Orange Metalic
    you will hit the fender before bottoming out the bumpstops, that's if the tire doesnt clear
    North Jersey
    2004 GTO M6
    Another thing is the tire you use. I don't know if this helps, but when I bought my 18" Sterns with BFG KDW2s, the rounder sidewalls didn't rub in the rear when going over bumps. When I replaced the rears with G-Force Sports, they rubbed. They were the same size(275-35-18), but the G-Forces look wider than the old KDW2s.
    KDW2 sidewall/contact patch from rear of car looks like this-\_______/
    G-Force Sport from rear of car looks like this-|_______|
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    Quote Originally Posted by redbird555 View Post
    Got any pics of this?
    Mar 2009
    here are the pics im going off of. mods please do not delete the link I know its to tech but it would not allow me to save the pictures and upload them to photobucket its just for demo purposes so please leave it up. http://www.ls1tech.com/forums/midwes...6k-beware.html The bump stops on my car were replaced with ones from a 3rd gen camaro because they are a hard rubber instead of soft. Coincidently the stops are also longer than the stock ones are I have about 2 3/8" of an inch between the bump stop and the axle and just a hair under 3 inches from the tire to the fender. Wouldnt that mean that the bump stop would hit the axle and bottom out before the tire ever got the chance to hit the fender?
    okc
    Silver 2002 WS.6
    Red 1989 Formula
    I think they look great!
    Mar 2009
    Ya I really like they way they stick out and give the car a more aggressive stance from the side plus the best part is the 17x11 wheel only weight 18.8 lbs and the front is around 16. If worse comes to worse I'll just get the jounce spacers that came on ss cars that limited suspension travel and put them on my bumpstops so it hits there before the fender
    North Jersey
    2004 GTO M6
    If that guy can pull it off, then so can you. That SS looks badass!!
    Mar 2009
    Also that ss is lowered an inch from what he's told me and has never had an issue so I think I'll be ok and like i said if worse comes to worse I'll add the jounce spacers to the bump stops. I love the way that car sits even though I'm not going for that full drag look I just think having the tires setup like that gives the car a more aggressive stance lol
    North Jersey
    2004 GTO M6
    You could always add drag bags if needed.
    Mar 2009
    heres one other shot I found I really think they will work after seeing this its the first pic in post 36 it shows the rear tires. I think it will clear fine with rolling the fenders. http://www.ls1tech.com/forums/wheels...t-lites-2.html
    Coral Springs, Fl
    Doesn't that one have a slightly larger offset?
    Mar 2009
    no alex, as long as your looking at the first pic in post 36 which is a white car that is the 7.5 offset the 7.75 is on the som car and puts the tire even further in
    Coral Springs, Fl
    Mar 2009
    You said larger, the ones on the white car are 7.5 vs 7.75 on the som car so wouldnt that mean they have the smaller offset from the axle? Unless im confused on how backspace and offset are related
    Jun 2010
    coxs creek
    00 T/A
    Not sure about your fitment but the car will look great with those wheels, I put 15x10's with 7.5 and 3 1/2"s on my car, 2300 bucks later in brakes they fit great
    Coral Springs, Fl
    Larger offset pushes the wheel in more
    Mar 2009
    OK so then no those ones have the smaller offset like I said because they stick out of the fenders more. This is the same car you said you didnt like as much because the tires stuck out ie smaller backspacing which is the same idea as a smaller offset.
  1. Billet Specialties brings new wheels to production
    Last Post: 12-14-2013, 11:22 AM
  2. Billet Specialties Street lite Custom Center Cap
    By chevuman260 in forum Wheels and Tires
    Last Post: 03-30-2013, 09:29 PM
  3. Question: Billet Specialties? anyone running em?
    By MudStainKILLA in forum Wheels and Tires
    Last Post: 01-22-2012, 09:40 AM
  4. Billet Specialties Wheels & Nova Steering Rack - C
    Last Post: 07-01-2009, 10:20 AM
  5. Hurst Billet Plus Question/Problem
    By aerojt in forum Manual Transmission
    Last Post: 07-20-2007, 12:58 PM
