Thread: head question
    Apr 2010
    Orlando
    2002 Camaro SS
    head question
    I have a chance of getting 244 casting heads for my 2002 camaro SS and was wondering if they are worth the change. If so does anyone know what kind of power I can expect from them. They are stock 244 heads. Also is there anything I should do to them before I bolt them on? any help would be appreciated
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    Quote Originally Posted by cags07 View Post
    Do you mean 243? The only info I found on 244s were ford/volvo heads. But if they are good heads I would get a port job at the very least on them along with replacing the valve springs and other things.
    Apr 2010
    Orlando
    2002 Camaro SS
    Woops.. Yeah sorry I meant 243 my mistake was typing did not read as Iwas doing it. But does anyone know the power that I would get from them and if it is worth the swap
    Apr 2010
    Alabama
    Black/ Silver
    Yea its worth it man. But I'd definitely get a port job to get the full benefits. You would probably gain somewhere between 30-50 horsepower maybe more.
    Aug 2001
    San Diego, CA
    383 w/Meth & ProCharger
    2001 Camaro Z28
    243 heads are stock LS6 heads. Your 2002 Camaro SS "may" have those already on it. Some 2002's have LS6 motors. Otherwise you have stock LS1 241 heads. So to swap to 243's stock would be a very slight improvement. Not worth the hassle really. But like 98TransAmWs-6 said...getting them ported and polished and maybe having a valve job done would really make a difference at that point. So buy the heads cheap then put some $$$ into doing 'em up good.
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Seriously?
    While some LS6 blocks were used to make LS1 engines (only difference is the LS6 is a "window design" and they used them as they ran out of LS1 blocks) no Camaro came equipped with an LS6 engine from the factory.
    If his car is unmodded and not a tuner car (GMMG, Earnhardt etc) then I have no doubt it has 241 heads on it.
    Apr 2010
    Orlando
    2002 Camaro SS
    Yeah I definitely have 241 heads I can get a set for around 400 bucks but was not sure if It was worth it just the way they were to bolt them right on or not
  1. Another Head and Cam question
    By 98TransAmWs-6 in forum Internal Engine
    Last Post: 04-18-2012, 09:16 AM
  2. head/cam question
    By lsmaxxed in forum Firebird / WS6
    Last Post: 01-09-2012, 05:39 PM
  3. Head/Cam Question
    Last Post: 01-01-2011, 08:14 AM
  4. head question
    By MCCs WS6 in forum Internal Engine
    Last Post: 08-04-2007, 04:53 AM
  5. head question
    By dlmeadows in forum General Help
    Last Post: 07-20-2007, 03:46 PM
