Thread: Transmission fluid leak!!!
05-21-2011, 08:21 AM #12002 Arctic White T/A
- Sep 2009
- Houston , Texas
Metallic Pewter- 2002 SLP Firehawk
It's leaking out of the fitting on my radiator. Seems to be the line back to the transmission. Anything I can do??
05-21-2011, 08:39 AM #2
did you removed the fitting lately? Try to tight it down a bit (not alot) and see if it stops. is it the fitting on the hose itself?
05-21-2011, 08:52 AM #32002 Arctic White T/A
- Sep 2009
- Houston , Texas
Yea had to remove the radiator. Got in a wreck.
05-22-2011, 06:59 AM #4
ok start by tighting down the fitting alittle more. If it continues to leak then go to auto parts store and buy you a fitting to attach aftermarket tranny coolers, a piece of tranny fliud line, and a couple of band clamps. Replace the whole line and the new adapter should stop the leak.
05-22-2011, 08:50 AM #5
If tightening does not work, the flare on the tubing may be cracked. Look it over closely and if that is the case you may need to cut the end off and re-flare it. I believe there is enough slack in the line routing that you might be able to do this one time.
what Transmission fluid
By seweber in forum DrivetrainReplies: 4Last Post: 09-02-2011, 02:45 AM -
weird power steering fluid leak...
By Spaz in forum General HelpReplies: 22Last Post: 07-02-2009, 01:24 AM -
Power Steering Fluid Leak
By Arrison24 in forum General HelpReplies: 10Last Post: 09-18-2008, 07:28 AM -
Still a Slight Tranny Fluid Leak
By GULLETT17 in forum Automatic TransmissionReplies: 8Last Post: 08-25-2008, 11:49 AM -
By matthewaqui in forum General HelpReplies: 4Last Post: 09-08-2007, 10:47 PM
