    Orlando, FL
    Mean Black
    vibration noise?
    ok so here is the deal. Since I put the poly motor mounts im getting some engine vibration. Is not bad at all but lately I'm hearing this rattle noise that comes from the dash area. It only happens when I stop the car from motion and I hold the brake. If i put it in neutral or park is gone. If I pull the Ebrake while in gear is gone. If im on park and i move the steering wheel some I can hear but it won't stay long. If i accelerate slightly(like increasing the idle abit) is gone.
    I tried to locate it under the dash but i really can't pinpoint the noise. The
    1st time I had some noise I reached behind the engine and moved a harness that was against the firewall. that made it stop until now. i check behind the engine again and I cant feel anything rubbing against the firewall.
    so did someone experience this rattle/noise when they put their poly mounts? any areas i should check? this noise is really annoying. Thanks.
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    Possibly a wiring harness vibrating behind the dash. Is the center console loose by any chance?
    Orlando, FL
    Mean Black
    no, i check the console and its tight. The thing is that when i hear the noise I scan around with my ear and i can hear it behind the dash/engine firewall.
    North Jersey
    2004 GTO M6
    Did you check the oil pressure sender wire? Also, are you running the factory radio?
    Orlando, FL
    Mean Black
    i think thats the wire that I moved the 1st time. No, i have aftermarket radio
    North Jersey
    2004 GTO M6
    OK. How long is the wiring behind the radio? That harness could be contacting the HVAC harnesses. Just a thought.
  1. Help: Oscillating noise and vibration out of 10 bolt
    By BlackPearl in forum Drivetrain
    Last Post: 04-06-2012, 04:06 AM
  2. Help: Wierd noise and vibration??
    By flybird in forum Automatic Transmission
    Last Post: 02-27-2012, 04:14 PM
  3. console vibration and noise
    By JayTA98 in forum General Help
    Last Post: 07-17-2010, 06:06 AM
  4. Noise Vibration
    By Retired Cop in forum Firebird / WS6
    Last Post: 12-23-2008, 06:17 PM
  5. Question: Another noise and vibration!
    By JoshieDoom in forum General Help
    Last Post: 05-16-2008, 10:05 PM
