Results 1 to 13 of 13
Thread: LS1 Mystery: Need solving
05-18-2011, 09:41 PM #1Junior Member
- May 2011
- Stockton
Red white blue- 2007 GTM
I have a crate LS1 with an ASA cam. It is in a race car (road race) (PDG4.com). I have been running a prototype 10-40 Roush Valvoline syn. oil .082 zinc,in it for 2 years without any trouble at all. No longer available, I changed to Valvoline syn, blend of 5-30, 20-50 off road, .120 zinc oil. I am now getting a residue in my catch can that my pit helper says is water and now have a blown head gasket. It is thin like water but greenish like real thin oil. We just finished a 2 hour race and collected about 6 oz. of this liquid. The water level is still about where it is suppose to be. The oil level is correct. The engine never overheats. We are running the same lap times as normal. There is no evidence of water in the oil sump or valve covers. There is no vaporizing from the exhaust. Where or what could this liquid tell me? What does it all mean? Where would I look to fix it?
Thanks in advance.
GTMRACR
05-19-2011, 04:39 AM #2
05-19-2011, 05:34 AM #3Junior Member
- May 2011
- Stockton
I don't run antifreeze.
Should I try a hydrocarbon test to see if it is present in the water? I once had a ls that had a blown HG and it showed up there, but had symptoms of pressure in the header tank and over heating. This on has no symptoms of a gasket going bad. Before I make a move on the motor, I want to know where I am going.
Thanks.
05-19-2011, 05:58 AM #4O U 8 1 2
- Nov 1999
- over here...
how long was it sitting before you found it???
05-19-2011, 08:32 AM #5Spaz is My Mentor
is this something that has just been happening since the new oil?
05-19-2011, 03:15 PM #6Junior Member
- May 2011
- Stockton
SPAZ,
the car came into the pits and we always check the catch tank and I would guess about 5 to 10 minutes after a 2 hour race.
This started happening since I changed the oil to the other Valvoline product. With the 10-40 Roush oil, I had some "OIL" catch, about 1.5 quarts in 25 hour race. We wrote that off as being normal as the rings had not seated yet. When the rings appear to have seated (Oct), we got no oil in the catch can. (2 races) Then the oil change and the first race produced about 4 oz. of fluid and then this last one it was 6-8 oz.
What is the skinny on "Don't use 10-40 in GM motors"?
RM
05-19-2011, 03:21 PM #711 years of bangin gears
- Jan 2009
- North Jersey
Maybe condensation? What does the fluid smell like? If it doesn't smell "fishy" then it isn't coolant. And I doubt it's fuel. If all your fluids are topped off and the car is running strong consistently, then I am going with the condensate hunch.
05-19-2011, 04:57 PM #8Junior Member
- May 2011
- Stockton
Goat,
a couple years ago I had condensation from some hoses. changed those out and nothing since then. Don't run coolant, so it is not that in the can. It is thin like water and has a dark oily green tint to it. Pit guys say it is a head gasket but I don't think so. It has to be something else, or............could it be?
Thanks.
05-19-2011, 05:14 PM #9Junior Member
- May 2011
- Stockton
PDG4.com Here is the car and our team
05-19-2011, 05:33 PM #1011 years of bangin gears
- Jan 2009
- North Jersey
Possibly a mix of oil and water blowing past the rings.
05-19-2011, 06:07 PM #11
Couple of thoughts: You could send an oil sample out for analysis which will tell you what is in it; pressure test the cooling system; perform a compression check on the cylinders and look for any variance; and/or inspect your crankcase ventilation system to ensure that your connections are good and that there is no outside contamination entering it...
05-24-2011, 07:09 PM #12Junior Member
- May 2011
- Stockton
did the compression test. The plugs were all perfect. the color in the exhaust showed a little rich and concurred with the data. On deceleration, the right bank shows a little more richness according to the data sheet. We physically shot the temps on each cylinder and they are all within 5 degrees. We marked the water level in the header tank and no water was lost. The car ran for about 30 minutes and got to a running temp of 210 degrees. Checked the catch can and had a hint of water deposit but was not mixed with the oil. the crankcase and the valve cover hoses were in perfect order. We wre told at one time to check the top part of the valve covers and they shecked out to be straight oil and no moisture. What next?
GTMRACR
05-25-2011, 08:45 AM #13
Mystery MAF?
By pajeff02 in forum General HelpReplies: 47Last Post: 08-26-2015, 04:29 PM -
Help: Mystery Part
By duweller in forum Firebird / WS6Replies: 7Last Post: 06-14-2010, 06:07 AM -
Question: Marvel Mystery Oil in Gas/Oil in the LS1
By camaroluvr447 in forum Internal EngineReplies: 7Last Post: 10-07-2009, 08:27 AM -
marvel mystery oil...
By jray0305usa in forum Internal EngineReplies: 0Last Post: 03-05-2009, 06:26 PM -
99 Z-28 Electrical Mystery
By jterhar in forum General HelpReplies: 3Last Post: 09-21-2006, 06:38 AM
