Results 1 to 15 of 15
    Senior Member
    Detroit
    Black/Red/Black/Red
    98WS6/06MCSS/86GN/06H3
    1992 full size chevy blazer stiff gas pedal
    Guys This has been bugging me for a while, the pedal is stiff, the accelrator cable and transmission kick down cable has been changed. Any ideas what this could be?
    Member importhater81's Avatar
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Throttle body.
    Senior Member
    Detroit
    Black/Red/Black/Red
    Quote Originally Posted by importhater81 View Post
    Throttle body.
    ok.....i tried cleaning it......what else would u suggest?
    Member joestacey06's Avatar
    PA
    Lube the bracket that holds the pedal?
    Senior Member
    Detroit
    Black/Red/Black/Red
    Quote Originally Posted by joestacey06 View Post
    yeah i actually tried that also...............but thanks
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Quote Originally Posted by Murder after Midnight View Post
    The bushings in the throttle shaft itself might be worn out...causing the blades to bind.
    Pick up another throttle body.
    Senior Member
    Detroit
    Black/Red/Black/Red
    Cool any idea where i could find one i have not been able to find one thus far...
    Oct 2009
    chicagoland,Il
    02 ss camaro
    They are getting tougher to find, as they have been out of production for 16 years.Try a local auto parts store or a junkyard I guess.
    Pittsburgh
    2008 Hummer H3
    worn out throttle cable
    Oct 2009
    chicagoland,Il
    02 ss camaro
    Did you read the 1st post?He said it was already replaced.
    Senior Member
    Detroit
    Black/Red/Black/Red
    ok thanks importhater
    Pittsburgh
    2008 Hummer H3
    Murder, I would make sure of the throttle cables routeing, and that there are no kinks or flat spots in it.. Incase it got kinked or smashed either by you durring installation or in manufacture/production.
    As the carrier/cover for the cable is made of rubber or plastic coated over a coil of metal.. Did you use a pair of pliers on the end of it to pull it through the fire wall? If so could have smashed or crimped the outer cover by accident..
    Junior Member need4fun2469's Avatar
    Jun 2009
    Mesquite,Tx
    SOM
    2002 WS6
    did you lube the throttle cable before you installed it? I always squirted oil down the cable while holding it vertical
    PA
    I might be able to get a throttle body from a 94 5.7 from a suburban. If your interested pm me.
    Senior Member whitelightnin99's Avatar
    SC
    youre not the only having the same problem:
    http://coloradok5.com/forums/showthread.php?t=134716
    Aside from a kinked cable, not really sure what else would cause it
  1. For Sale: 1989 Chevrolet Blazer Blazer Full Size
    By bills98ta in forum Vehicles For Sale / Trade
    Last Post: 08-25-2010, 07:27 AM
  2. a/c on= stiff clutch pedal?
    By Ramairgod84 in forum General Help
    Last Post: 07-17-2010, 05:57 PM
  3. parting out 93 full size blazer
    By 0verkill in forum Parts For Sale / Trade
    Last Post: 07-16-2010, 03:18 PM
  4. For Sale: 1988 Chevrolet Blazer k-5 (full size)
    By gonzo99ta in forum Vehicles For Sale / Trade
    Last Post: 01-24-2010, 02:28 PM
  5. WTT Full Size 93 Blazer
    By 82blayser in forum Vehicles For Sale / Trade
    Last Post: 09-26-2007, 07:28 PM
