Results 1 to 20 of 27
    Member FMBL's Avatar
    Mar 2010
    NRH, TX
    1998 Z28
    Looking into getting a pistol
    Ok I wil list what I have now.
    Remington 12 ga semi
    Remington 16 ga semi
    Mossberg 410 bolt action
    Mossberg 20 ga single shot sawed off w/ pistol grip
    Marlin 30-30
    Remington 243 semi
    Remington 30-06 semi
    Rossi 22 pump
    Browning 25 semi
    I have never really been a pistol kind of guy. I am looking to get something for my wife 5' tall 101 lbs. I would like to get your opinions on semi auto pistols that have a small hand grip and not real heavy. Primary use shooting range and protection if needed.
    Thanks
    PA
    Ray Charles blue
    1492
    Lots of choices. Depends on what you want to spend.
    Hammerless revolvers are pretty cool too and easy to operate.
    Mar 2010
    NRH, TX
    1998 Z28
    Looks like $500-$600 range. I will take a look at the hammerless revolvers too.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    check out the airweights.
    PA
    Ray Charles blue
    1492
    There are a ton of options. Almost more than we can list.
    Mar 2010
    NRH, TX
    1998 Z28
    looking at the airweights. Thanks
    Mar 2010
    NRH, TX
    1998 Z28
    I am guessing hand guns just like rifles? A revolver will have more kick/recoil than a semi-auto?
    Centerville OH
    blue
    1999 TransAm
    Quote Originally Posted by FMBL View Post
    many factors here:
    generally (for a given cartridge/load), the heavier the gun the less perceived recoil... so, a little ruger LCR or LCP is probably a lot less pleasant to shoot than a .45 1911-style steel framed pistol. some of the lightweight revolvers would probably not make good range guns (unpleasant to shoot for the average person), and difficult for good aimed fire in SD situation..
    semi-auto pistols tend to alleviate recoil, by virtue of the reciprocating slide, that can reduce the impulse...
    if this will be "her" gun, you want to do it right and make sure she makes the ultimate decision - best bet is pick some out and rent at a local gun range (if you have one that rents guns), or go w/ some friends that have a few different kinds, perhaps mix of revolvers and pistols, have her shoot them - that would be a better way to "sort things out" IMO.
    Central Florida
    2000 Z28
    Why don't you go out with her and let her choose between a couple of different guns. A j-frame should be strictly a BUG, as a primary firearm, it makes too many compromises. While it's light and easy to conceal, recoil from modern self-defense .38sp +P's make recoil unpleasant. Which means she's not going to shoot much. While they are simple to operate, capacity is low and unless she trains a lot, reloading is slow. Also, .38sp is a little more expensive to shoot than 9MM.
    Stick with a modern poly-framed, striker fired pistol like a Gen 3 G19 (the new gen 4's have some teething issues), or S&W M&P. They are simple to operate, reliable, and handle recoil really well.
    Sent from my DROID2 using Tapatalk
    Mar 2010
    NRH, TX
    1998 Z28
    Ya I found a range here that has quite a few to rent to let her try out. Thanks for the input. I will let you know the out come of what we (she) decides.
    Centerville OH
    blue
    1999 TransAm
    Member cuervo25_1's Avatar
    Jun 2009
    Oakland NJ
    Steel blue pearlcoat
    2000 dodge intrepid
    First key to any firearm is what feels good to you. meaning how it fits in your hand (s) to your shoulder ect. It may have a small handgrip but does it fit well in her hand or is she comfortable holding it. then you go to what she is comfortable using, if she flinches while fireing a certain handgun you will have to try more to see which ones she don't flinch with. those two things alone could make or break someone getting their first handgun.
    I never had experiance with a firearm with a compensator but they are supposed to compensate for the lightness of a handgun by letting some gasses escape at the end of the barrel before the bullet leaves to give downward force causing less recoil. Like I said I have no experiance with them so if it works well or if there is a significant amount of power loss I don't know, but it is worth looking into since you have a range where you can rent hanguns.
    Central Florida
    2000 Z28
    Comps on pistols are almost exclusively used on open division IPSC/USPSA pistols (except Glock models with the C suffix) where the load is tailored to the pistol to reduce muzzle rise. I wouldn't use one on a defense pistol because the muzzle blast can be distracting to my sight picture. You don't see any LE/MIL agencies issuing them.
    oklahoma
    98 Trans Am Ws6
    Normally I would go with my beretta px4 subcompact but the grip would most likely be the wrong size. I would take a good look at the XD subcompact by springfield.
    EDIT:
    Just noticed it isnt for cc. Just go for the full size xd.
    The Herpes of LS1.com Modulistic's Avatar
    Kodiak, AK
    gray
    07 duramax
    Tokarev
    Central Florida
    2000 Z28
    The XD line is a popular choice also. The issue I have with the XD is the grip/drop/sear block safety. It blocks the slide from being manipulated without depressing it. What does it do that a trigger operated drop safety doesn't? I suppose it's something you can train around, but no major LE agencies issue it, and you don't see major competitors @ IPSC/USPSA/IDPA events shooting them.
    Nov 2008
    Levittown PA
    02 Trans Am Vert
    My wife hated the Airweight, too much recoil. Try a Ruger SP101 heavier frame, same size and shoots 38/.357. Also a nice choice is a Sig P239.
    Marylandistan
    2001 Trans Am (sold)
    Small hand grip semi check out the H&K P2000.
    oklahoma
    98 Trans Am Ws6
    pretty much you cant go wrong with any major brand
    Central Florida
    2000 Z28
    Quote Originally Posted by garver View Post
    Except Taurus. Friends don't let friends shoot Taurus.
  1. What’s the Best .45 Subcompact Pistol on the Market?
    Last Post: 02-17-2013, 08:07 PM
  2. The Caracal Pistol
    Last Post: 04-23-2012, 12:50 PM
  3. Replies: 0
    Last Post: 04-12-2012, 03:50 PM
  4. Introducing the Springfield XDs Pistol
    Last Post: 01-18-2012, 11:41 PM
  5. Where do you keep your pistol?
    By mroby in forum Gun's & Ammo
    Last Post: 08-31-2010, 11:39 PM
