Thread: Stall question for FI
05-11-2011, 11:21 AM #1
- Apr 2010
- Alabama
I have a torque converter question. I am trying to decide what stall to get. My goals for my TA is to make it into a high speed handling road racer. I plan on procharging it at some point and before that I am going to put in a blower cam with these specs 232/240 .595/.608 LSA 115 and I am wondering what size stall should I run. I was thinking of a 4000 stall but I was reading that prochargers really start making power around 3000 and started to wonder if a 4000 stall would actually hurt the power I will be making instead of helping. So my question in this case is would it be better to run something in the 3000s or would a 4000 stall be better.
05-11-2011, 12:05 PM #2
- Lemont, IL
Black- 2002 Trans Am WS6
I just had a Yank SS3600 installed and I couldn't be happier with it. Granted, I am still on stock internals, but I wouldn't go any higher on an FI motor, regardless of cam specs.
Also, if you care about true high speed characteristics, a more agressive stall with a higher STR will impact efficiency and potentially reduce top end performance.
I'm no expert, but that's my direct experience. I think with a 4000 you're stalling into the meat of your powerband and you're not taking advantage of a good bit of power you're making, not to mention you'll blow the tires off the car when that power hits.
My setup will destroy the ET Streets all through first gear as-is and I don't have a very aggressive setup.
Here's a very rough instrument panel video to give you an idea:
[ame]http://www.youtube.com/watch?v=Sv6eQ3d2Bcs[/ame]
Ultimately though, I would suggest you contact a reputable TC manufacturer and ask them this question. They will be able to give you a definitive answer based upon your input regarding power levels, weight, performance goals, driveability, etc. I think Yank and Circle D are great places to start, but that's just an opinion.Nick
2002 Trans Am WS6 - 520rwhp
D1SC @ 10lbs | FLT Level V - SS3600 - ARH 1 3/4" LTs w/ Catted Y-pipe - Corsa - Koni 4/3's - UMI Adj. LCAs and Brackets - UMI 3 Pt. SFC's - UMI PHB - UMI STB - TTM's (17X9, 17X10.5) - M/T ET Streets
05-11-2011, 01:19 PM #3
05-12-2011, 07:02 PM #4
- Apr 2010
- Alabama
I talked to circle d and they suggested their 258mm converter with either single or multi disc lock up with a 3200-3400 stall. What are the benefits and or disadvantages of single vs multi lock up?
05-12-2011, 09:43 PM #5
My friend had the multi disc in his c5 and it is modded and see's a lot of track time and is now getting a stroked 421 if I remember right and his stall has never had an issue yet after years of hard driving. I have a circle d 3200 street stall and works great for almost a year now. Going to upgrade to a 3600 to fit my cam better but those guy build great stalls and never heard of anyone here having one go bad yet.
1998 Trans Am 85k miles.
02 Trailblazer -Sold
09 Ram 1500 CC - Sold
09 Cobalt SS/TC - Sold
05-13-2011, 11:13 AM #6
- Lemont, IL
I don't know that there are disadvantages with either, aside from the $2-300 more you typically pay for a multi-disc setup. The multi-disc is going to be even more durable than the single and have more clutch area, but I don't think you NEED to go that extreme with your setup. That's not to say that a good single disc is weak by any means, just that the multi will take things a step further.
I know Chris advertises WOT lock-up with his multi-disc converters, but it may be overkill depending on how far you go with your FI setup. Typically a good, billet single disc will be plenty for most people. I'm not sure how the multi-discs drive on the street either, could potentially be a harsher lock-up engagement as well.
05-14-2011, 07:11 PM #7
05-26-2011, 11:07 AM #8
- Staten Island, NY
2007 Cadillac Escalade- 98 Camaro SS, 09 G8 GT
The main difference between a single disk and multi disk converter is you can lockup a multi disk at WOT.
05-26-2011, 11:20 AM #9
- Apr 2010
- Alabama
I know that much. I was more of wondering if its worth the extra $300 and in what situations would a multi disc be better, like when would I need a multi disc over a single.
Stall Question!
By st_cspeer in forum Automatic TransmissionReplies: 7Last Post: 11-13-2009, 10:07 AM -
stall question again (HELP)
By stefos in forum Automatic TransmissionReplies: 22Last Post: 12-26-2008, 07:21 PM -
to stall or not to stall that is the question
By Bandit1 in forum DrivetrainReplies: 21Last Post: 07-08-2008, 07:26 AM -
Stall question
By LETHALxLS1 in forum Automatic TransmissionReplies: 6Last Post: 07-08-2007, 03:56 PM -
a4 Stall Question
By pipes_ta in forum Automatic TransmissionReplies: 2Last Post: 10-17-2006, 06:16 PM
