Thread: alternator removal
05-09-2011, 07:04 AM #1Junior Member
- Dec 2010
- st louis mo
medium blue metallic- 1999 trans am
alternator removal
i need some help here people....couldn't find a write up on how to remove the alternator..im changing my rack and pinion and it says i need to remove the alternator. gettin frustrated
05-09-2011, 07:14 AM #2Senior Member
- Oct 2008
- Coral Springs, Fl
Can't remember if I had to remove the bracket for it but its not that bad. Make sure you watch out not to break the plug on top, its extremely fragile
05-09-2011, 01:14 PM #3
Well for starters take your battery cable off so there is not power. Remove the cable from the alternator nut. there is a small bracket behind the alternator that it has one bolt to the alternator and another bolt to the block. Remove this bracket. you can reinstall it after but I don't see I use for it so I never reinstall it back.
You have to disconnect the red wire plug on top of the alternator. Thats the plug that goes to the PCM. it is a very small wire and easy to break if you dont unplug it before removing the alternator. Is kinda hard to reach the plastic release of the plug. I use a small angled flat screwdriver.
I can insert and twist the screwdriver behind the plastic relaese and unplug the red wire.
I have always remove the bracket that holds the alternator. Somehow I can't get the alternator out without removing it. You have 2 bolts that hold the alternator and one for the bracket.
You should be able to remove the alternator at that point.
05-09-2011, 01:36 PM #4Spaz is My Mentor
I'll add that if you do break the thin wire don't sweat it there is a sticky on how you can fix it.
05-09-2011, 01:37 PM #5
and the plug is easy to buy as well.
05-10-2011, 11:13 AM #6
11-15-2015, 02:27 PM #7Junior Member
- Apr 2006
- Michigan
Black- 2002 ws6
Where's the sticky on how to fix this plug? Just replaced my alternator and found this plug without wire, and this wire... without a plug.
Thanks!
--alex
11-15-2015, 05:20 PM #8
Is this what you are referring to?
Sticky: http://www.ls1.com/forums/f6/fix-if-...re-plu-133361/
Alternator Instructions (Removal and Installation)
By blackhawk01 in forum External EngineReplies: 24Last Post: 05-25-2016, 05:08 AM -
alternator pulley removal
By silver99ss in forum General HelpReplies: 3Last Post: 01-02-2009, 01:13 PM -
alternator
By tingo99 in forum Internal EngineReplies: 5Last Post: 03-19-2008, 07:45 AM -
alternator
By RIVERRATT in forum Parts For Sale / TradeReplies: 0Last Post: 10-04-2007, 08:58 AM -
Alternator Pulley Removal??
By chevyin55 in forum External EngineReplies: 1Last Post: 03-13-2006, 04:16 PM
