Thread: Which would you choose...
05-05-2011, 01:39 PM #1
Not looking forward to breaking my rear extension housing on my transmission when I get home for R&R again, so Im looking to purchase a relocaton bracket for the torque arm or the adjustable torqur arm. Just looking for some insight on which one I should get
05-05-2011, 02:02 PM #2None Shall Pass
- Jan 2010
- East of Cleveland, Ohio
Black- 99 WS.6 - Modified
I use a Global West Traclink torque arm on mine. Love it. Adjustable to suit your needs, but might be a bit of overkill for a strictly street driven car.
05-05-2011, 02:14 PM #3
I do street racing when Im home
05-05-2011, 02:42 PM #4
If you plan on staying on the street with your car, get a full-length adjustable torque arm that gets the front mount of the torque arm off the tailshaft of the transmission.
The other route is a tunnel brace torque arm that is shorter; mostly used for track use though. Typically since it's mounted in the tunnel, you will transmit a little bit more road noise.
Either way, get one that is a) adjustable and b) that mounts off the tailshaft of the transmission.
UMI sells some pretty nice pieces.
I personally went with a TrakPak from BMR...probably a little too "stout" for your application
05-05-2011, 03:52 PM #5Electrical Engineer
- Jul 2009
- North of the Motorcity
When you get a relocation bracket you have to get a new TA.
Like 35th said:
Track car = Relocation hardware + New relocated adjustable TA
DD = New adjustable TA
Do you ever plan on replacing your rear end? Another reason to consider adjustable. Lowering is too.
If you go with the tunnel relocation kit, I would get the one with the DSL. Also, you'll need to know if you want to do long tube headers, as they need to be taken into consideration when getting a tunnel brace.
Oh, I also vote for UMI.
Help: Help me choose a cam for a 350
By Mr. D in forum Internal EngineReplies: 16Last Post: 06-01-2010, 04:18 PM -
Trying to choose between 2 T/As?
By SMWS6TA in forum Firebird / WS6Replies: 16Last Post: 02-27-2009, 08:14 AM -
Getting a cam, 2 to choose from. Which one?
By Y2K_CAMARO in forum Internal EngineReplies: 90Last Post: 12-21-2008, 05:33 AM -
HELP me Choose a new car!!!!!!!!!!!!
By Zboner in forum Almost Anything GoesReplies: 91Last Post: 09-08-2008, 04:15 PM -
Which would you choose?
By Z28LS1 in forum External EngineReplies: 9Last Post: 07-05-2007, 06:01 PM
