Results 1 to 15 of 15
05-04-2011, 01:53 PM #1
Is my radio/ amp bad? (Front speakers sound blown)
So, I dropped my car off at a local shop to have the rear hatch tinted. While there I asked them to check my front speakers as they sound like they're blown when I turn up the volume.
The shop called and said they replaced the speakers which did not solve the problem. They say they suspect it's either the radio or the amp...
Any input would be appreciated!
BTW I'm NOT a big stereo person. I have no interest in amps, kicker boxes or anything like that. I just want my radio to play.....
05-04-2011, 05:45 PM #2Electrical Engineer
- Jul 2009
- North of the Motorcity
Stock or aftermarket equipment?
05-04-2011, 06:16 PM #3Completely stock Monsoon sound system.Stock or aftermarket equipment?
05-05-2011, 03:04 PM #4Electrical Engineer
- Jul 2009
So the new speakers make the same noise as the old stockers? Do your trust the shop? Did you see them actually install new speakers? Is it the radio or cd player or both that produce the shitty sound?
If the amp was blown, you probably wouldn't be getting any signal for any speaker.
05-05-2011, 03:07 PM #5
There is a separate amp in our cars for the rear hatch speakers correct? And the front and rear sail-panel speakers run off of the radio amp? Just curious. Been awhile since I thought about the Monsoon stereo system.
05-05-2011, 03:14 PM #6Radio and CD player both make the same sound, and I do trust the shop. I've been dealing with them for years. They seem to think the speakers seem to be replaced with GM monsoon speakers, does that sound right? BTW they are trying to find used units an new GM speakers are $$$$$.So the new speakers make the same noise as the old stockers? Do your trust the shop? Did you see them actually install new speakers? Is it the radio or CD player or both that produce the shitty sound?
Man, I have no idea. As mentioned, I'm not really a "Radio" guy. I just want to hear my tunes.....There is a separate amp in our cars for the rear hatch speakers correct? And the front and rear sail-panel speakers run off of the radio amp? Just curious. Been awhile since I thought about the Monsoon stereo system.
05-05-2011, 03:18 PM #7
Well the reason I ask is because if all 4 speakers run off the amp in the radio, all 4 speakers should be getting a weak signal if the amp itself is going out.
You mentioned you are just getting a shitty sound to the fronts.
Have you pulled the radio and checked the wiring?
Also - is it at all volumes or just when you turn it up? I had loose grille covers in the front of my 96 I had which vibrated during loud volume...which in turn made the speakers in the front "sound" like shit...even though they were fine.
Just to check, you could hold your hand to the grille to make it tight while the speaker is playing and see if that makes an improvement.
05-05-2011, 03:38 PM #8Electrical Engineer
- Jul 2009
^ If that doesn't work and you want to get it done fast, you could start replacing components.
I would bet on the HU being at fault first, but I would be checking the wiring and speakers first myself. Meaning, hooking your stock spears up to a a different working location to make sure their good or bad.
05-05-2011, 05:31 PM #9Junior Member
- May 2011
- Boston Ma
Silver- 2002 WS6 Trans Am
what kind of sound dose the speaker make is it a crackle or a hummmmmm
05-05-2011, 05:43 PM #10Yup, just the fronts.You mentioned you are just getting a shitty sound to the fronts.
It's just when I turn it up.....Also - is it at all volumes or just when you turn it up?
Thanks for the idea, but it's not the grilles.Just to check, you could hold your hand to the grille to make it tight while the speaker is playing and see if that makes an improvement.
Would an aftermarket stereo work with the rest of the Monsoon components, or would you have to replace everything?^ If that doesn't work and you want to get it done fast, you could start replacing components. I would bet on the HU being at fault first
05-06-2011, 02:54 AM #11
If you a bad or bad speakers you can swap one of them with one of the good ones to be sure is bad. If the problem follows the speaker then it is the speaker. If the speakers are good then it could be wiring, amp or the radio.
You could have one or more speakers not working properly with a bad amp. I have a JL 6 channel amp and I had one channel that when out. The rest worked fine. So it could be an amp issue or radio issue.
05-06-2011, 09:15 AM #12
05-06-2011, 11:35 AM #13No it's certainly not a bad system, I admit though, I wouldn't mind having something with an IPOD jack...I believe they make HU's now that do. I'm not sure b/c I don't mind the monsoon, it's far from the worst system ever put into a vehicle.
BTW, at this point consensus is either a bad head unit or amp......
05-06-2011, 11:55 AM #14
05-06-2011, 04:38 PM #15Copy that!You could buy a HU with iPod jack, and if it doesn't solve your problem, just return it, lol.
Help: Front speakers sound bad
By mdcrabbie in forum Stereo and ElectronicsReplies: 7Last Post: 04-19-2010, 06:14 PM -
Question: Weak sound from front speakers
By SMWS6TA in forum Stereo and ElectronicsReplies: 3Last Post: 10-06-2009, 04:20 AM -
Rear speakers sound blown
By matt123 in forum Stereo and ElectronicsReplies: 4Last Post: 05-01-2007, 11:22 AM -
Blown front speakers in SS Convertible
By daveinstl in forum Stereo and ElectronicsReplies: 64Last Post: 04-18-2007, 08:07 PM -
Front speakers blown
By mrbob2 in forum Stereo and ElectronicsReplies: 14Last Post: 11-04-2006, 06:49 AM
