Thread: Heads Any Ideas?
05-04-2011, 08:09 AM #1
Heads Any Ideas?
So this could be a vauge question just out of curiousity wondering where i should go from here besides a new rear end. So is there a cheaper way out to buying heads like som off a LS2 ported or something?? Just throw some ideas out here besides spending thousands on a set of heads. Thanks. Oh and as of now i have a custom ground cam 231/235 116 dynoed at 394rwhp.
05-05-2011, 02:33 AM #2
The 243 heads off of an ls2 are the same as the heads off of a z06, just has normal valves and not the light valves...you can usually pick a set of used ones up for around or under $500
05-05-2011, 10:19 AM #3
05-05-2011, 10:46 AM #4
Id definitely get them ported 1st...if not you won't see much gain over stock.
If your PTV clearance is good I'd get them milled some too to give a bump in compression
05-05-2011, 11:44 AM #5
Ok cool ya ill do What I can and see what i can find around here to mill them
05-06-2011, 01:32 AM #6
Late-Model GTO Heads and Cam - The Voice Inside Our Heads, P
By Ed Blown Vert in forum GTOReplies: 0Last Post: 03-16-2011, 09:30 AM -
By Ed Blown Vert in forum GTOReplies: 0Last Post: 02-04-2011, 02:00 PM -
Affordable Cylinder Heads - E-Street Heads
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-14-2009, 01:20 AM -
ideas heads for 408
By lancesT/A in forum Internal EngineReplies: 23Last Post: 07-11-2009, 08:15 AM
