Results 1 to 20 of 23
Thread: Rear axle
04-30-2011, 08:27 PM #1Junior Member
- Oct 2010
- Lufkin, Tx
- Blog Entries
- 2
Pewter- 99 Chevrolet Camaro Z28
Rear axle
OK so my rear axle or differential or how ever you guys want to call it just went out on me it doesnt get a hold of the gears all it does is my drive shaft just spins and makes a knocking noise i took off the plate that covers up the box and my gears are are grinded down
what should i do? should i just go with a stock one or should i put a different one on my car?
05-01-2011, 04:26 AM #2
Time for an upgrade ! Moser 12 bolt or a 9" !!!
05-01-2011, 06:56 AM #3
05-01-2011, 07:38 AM #4
You have an auto or a manual, how much power do you make and intend on making?
05-01-2011, 09:43 AM #5Junior Member
- Oct 2010
- Lufkin, Tx
- Blog Entries
- 2
05-01-2011, 09:47 AM #6Junior Member
- Oct 2010
- Lufkin, Tx
- Blog Entries
- 2
05-01-2011, 10:05 AM #7
The manual is pretty hard on the 10-bolts so you should probably go with an aftermarket rear end as mentioned.
Moser makes both, the 12-bolt and the 9".
Plenty of other companies offer rear ends as well. If you didn't know already, they cost more than 2 grand.
05-01-2011, 10:16 AM #8Junior Member
- Oct 2010
- Lufkin, Tx
- Blog Entries
- 2
05-01-2011, 10:26 AM #9
9" is stronger, almost unbreakable, but I believe it is heavier and has more rotational mass (lose a little HP)
12-bolt is supposedly not as strong as the 9" but I've never seen anyone break one personally either.
You can get these a lot of places, texas speed, or go straight to moser.
Midwest Chassis makes rear ends as well. Just do a google search cuz there are quite a few options out there.
05-01-2011, 11:00 AM #10
2018 Tahoe - Silver - OEM
05-01-2011, 11:25 AM #11
Usually the autos go with the 12-bolt because they don't need a super strong rear and they have less rotational mass, so yea, that could be why they don't break as easily.
05-01-2011, 02:34 PM #12
That and in an A4, you can preload the drivetrain for launches, which takes all the stress and backlash off the rear... as opposed to an M6 car where you pop the clutch and pop your rear end right out of the 10 bolt.
That's why they say M6 cars go with the 9" because it's a free floating carrier. At least this is what I remember while doing a little research for myself before buying my 9".
05-01-2011, 06:00 PM #13Junior Member
- Oct 2010
- Lufkin, Tx
- Blog Entries
- 2
05-01-2011, 06:07 PM #14
A4 = automatic 4-speed
M6 = Manual 6-speed
05-01-2011, 06:37 PM #15
I have a Moser 12 bolt,i would STRONGLY recommend order whatever you decide to with straight from the manufacturer.another option is the Strange S60 which is quite strong.
Posted via Mobile Device
05-01-2011, 06:59 PM #16
Moser 9' or Strange 12 bolt.
05-02-2011, 04:56 PM #17Junior Member
- Oct 2010
- Lufkin, Tx
- Blog Entries
- 2
05-02-2011, 05:53 PM #18
Here's how it breaks down:
Strength:
Dana > 9" > 12 bolt
Weight:
Dana > 9" > 12 bolt
Efficiency:
12 bolt > 9" > Dana
Our car is an A4 that sees track duty. I went with a Moser 12 bolt, but in hindsight may have been happier with a Strange 12 bolt.
05-02-2011, 05:54 PM #19
Dana=Strange S60
05-02-2011, 05:57 PM #20
rear axle need help
By drago1217 in forum DrivetrainReplies: 6Last Post: 04-30-2010, 02:40 PM -
new rear axle
By barryz in forum Manual TransmissionReplies: 0Last Post: 07-25-2008, 10:48 AM -
SLP Rear axle
By lude97 in forum Parts For Sale / TradeReplies: 16Last Post: 07-06-2007, 03:32 PM -
Rear Axle/Rear Grear Problem
By ob02z28 in forum Manual TransmissionReplies: 0Last Post: 01-22-2007, 10:32 AM -
99 Rear Axle
By speedkills in forum Parts For Sale / TradeReplies: 0Last Post: 01-12-2007, 06:10 PM
