Thread: halos
04-25-2011, 02:19 PM #1
halos
i was just curious and idk if this is a stupid question, but ive been looking into new lights, and i like the HID's but idk if i want to mess with all that right now. i dont really like the 3 lights with the halo in the middle, i found these, which are black like i prefer, and they look good.. but they have that stupid led light thing on the side.. is there anyway to get rid of that? has it been done before?
http://www.hawksthirdgenparts.com/ca...black-1-1.aspx
04-25-2011, 02:51 PM #211 years of bangin gears
- Jan 2009
- North Jersey
You could leave the halos unwired so they don't work, or you could wire them up to a separate switch so they don't come on if you don't want or come on when you want.
04-28-2011, 04:31 PM #3Member
- Nov 2009
- North Carolina
Black- 2001 Camaro Z28
you can choose not to hook them up at all, i wired mine in to where they flashed with my turn signal
04-28-2011, 09:09 PM #4
Go with the sonars. I had those and the light output was worse than stock. I even had HIDs in them.
These are the sonars.
http://cgi.ebay.com/ebaymotors/SONAR...Q5fAccessories2002 Artic White SS 35th Wheels|Full Hotchkis Suspension|Koni SA|Magnaflow CME|SLP lid|www.fquick.com/The_Guz
04-29-2011, 07:41 AM #5
I have halos on my car not from the website in question but off ebay. Mine are wired to my turn signals or daytime running lamps and you cant tell that there on at all not strong enough, unless its night time but then the headlights turn on and it just blends in and cant see them anyway.
1993 Z28 M6: K&N Intake, 52mm TB, TB Bypass, No Cats, Exhaust Cutout, Flowmaster Muffler, 3.90 Gears, 160 Thermo, Tune, BMR Springs, Bilstein Shocks, 3 Point SFC,s & MGW Shifter.
04-29-2011, 10:01 AM #6
HALOS are ASS!!! the ones I have fit bad and the rubber around the lens suck to. I'm getting stock headlights and painting the inside blk.
04-29-2011, 01:40 PM #7
Good point forgot about the POS rubber thats around it. They peel off, i had to crazy glue mine back on lol. Also for some reason the aftermarket ones fog up and scratch easy. I dont know so far with some crazy glue mine are ok but as mentioned your better off with stocks.
04-29-2011, 10:30 PM #8
the housing is cheap and poorly made. Had a clip break after install and a halo went out LOL
Halos
By sdavenp8 in forum Camaro / SSReplies: 1Last Post: 09-26-2011, 02:37 PM -
which halos
By BMJ99Z28 in forum Appearance SectionReplies: 8Last Post: 06-19-2009, 09:15 PM -
Help: Halos + HID?!?!?! Help
By LS1Powerhouse in forum Appearance SectionReplies: 28Last Post: 05-19-2009, 12:21 AM -
clear halos or black halos?
By bowtieguy02SS in forum Camaro / SSReplies: 54Last Post: 01-19-2009, 11:23 AM -
Halos or No ?
By Crimson Sin in forum Camaro / SSReplies: 7Last Post: 10-08-2008, 10:45 AM
