Results 1 to 13 of 13
    Aug 2010
    Savannah, Ga
    Blue
    2001 TA WS6, 1995 BMW M3
    Is 150hp shot too much???
    I'm sure that this has been beat to death, but I can't find a solid opinion. I'm looking to install HSW's 150 Wet plate kit.
    Current setup: SLP Lid, Smooth bellow, S3 TB, LS6 Intake, Underdrive pulley, MS3, Patriot Dual springs, P/P LS1 heads, Tuning by: Carter Racing of Savannah, Ga (447rwhp/432tq), Luk Pro Gold clutch, Fidanza Aluminum flywheel, Built XMSN, 9" w/ 3.73, Pro 5.0 shifter, Pacesetter long tube, ORY, Flowmaster w/ electric cutout, Koni Struts/springs, SFC's
    The motor just passed 100k miles, but runs stronger than ever. I have 42# injectors and a dual fuel pump setup also. Ultimately, would a 150 shot be too much or should i stay around the 100 shot range for now?? Thanks.
    Aug 2000
    Indy
    my opinion, a 100-125
    04 C5 A4 Torch Red - sold
    2009 CTS4 Ice Black - sold
    2013 1500 Silverado Z71 - sold
    02 Z/28 M6 Onyx Black All Options - Sold
    2014 Caddy CTS4 - DD
    2016 Silverado 2500HD
    2020 Caddy XT6
    2020 2SS Vert
    Senior Member bills98ta's Avatar
    Feb 2007
    St Thomas, PA
    Stock rod bolts ? Uhhmmm... I sprayed a 150 shot in mine for over 4 years, before it pulled a rod bolt, with a lot less miles on it...
    Junior Member White99ta's Avatar
    Apr 2011
    beaufort, sc
    99 trans am
    Where's that place in Savannah? I'm stationed in beaufort sc. I think I've seen you around before, if it was you the car sounds great.
    Aug 2010
    Savannah, Ga
    Blue
    Quote Originally Posted by White99ta View Post
    Carter Racing is located on Abercorn Rd behind Portman's Music. I have a few friends that live in Beaufort that i go and hang out with on occasion. You've probably seen me up there as well. Thanks for the shout-out.
    Aug 2010
    Savannah, Ga
    Blue
    Quote Originally Posted by bills98ta View Post
    I'll probably start with a 100 shot. From there it will be baby steps to get it tuned for the 150. We'll see though, i may be just happy with a 100... that'll put me around the 550rwhp range. I'll be fine with that for a little while.
    Member jrgswhitels1's Avatar
    Feb 2007
    In front of you, where else?
    1993 Camaro Z28
    100 shot is what Im running on my Z. More than that is on your fueling and tune so....good luck!
    1993 Black Camaro Z28 LT-Won
    Junior Member ReaperchildZ28's Avatar
    May 2011
    Bahrain
    99 Z28
    Well its really a matter of Tuning - PCM, Mixture.
    I'd make sure my injector duty cycle is below 80% & also have effecient fuel supported to the fuel rails. We all know ppl whom got away on a 200shot in a stock bottom end but if you want to risk it for a price of a new motor .. Its your call ... Race fuel 110 or min 106 for elemenating some detonation but I won't completely depend on that either .. Key is effecient Tuning & watching your spark plugs fuel pressure A/F ratio & LUCK !!
    Alawi
    99 NBM Z/28 M6
    http://www.ls1.com/forums/image.php?type=sigpic&userid=72678&dateline=130557  0961
    Member Never-Enough's Avatar
    Dec 2010
    PA
    Atomic Orange
    2007 Z06
    Too much? No.
    What I would do? No.
    I would go 125 tops unless I had a built motor.
    I sprayed 150 on the built 306 in my old LX & I only went up to 100 on my last car I sprayed (2010 Genesis Coupe 3.8)
    May 2011
    o*c
    2001 T/A WS6 sold...
    naaaaa itll hang...ur gonna make sick power
    May 2011
    Frederick MD
    I started with a 100 shot and am looking to go to a 150 shot. I have a stock bottom end and a H/C/I car with a nitrous outlet 92mm plate system. The tuner told me that 150 is safe to spray on these motors as long as the tune is spot on. I have seen guys on other forums spraying 200 on a stock bottom end for many passes
    Arizona
    I've never seen 200 on the stock LS1, but that doesn't mean you can't.
    A friend of mine ran a 175 shot on his 98 for 2 years. Started doing it at 60,000 miles and sold the car, still running strong with right at 100,000 miles.
    Probably 100 passes at the strip and numerous street encounters spraying it. Just gears and exhaust with some tuning were his only mods. The rest was bone stock. I think it went a best of 11.30 at 117 mph. Consistent too. Always went several rounds bracket racing it.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    You will be just fine with 150-175 with the correct plugs & tune. I have been spraying anything & everything for years & have yet to blow Anything up. You want to make Sure you keep any oil out of the combustion chamber as it will cause detonation.
  1. How to Prep Your First 150hp Nitrous Shot
    By Ed Blown Vert in forum General Help
    Last Post: 09-21-2012, 05:50 PM
  2. !!!150 shot my ass!!!
    By WICKEDLS1 in forum Kill Stories
    Last Post: 12-29-2010, 10:43 AM
  3. Does 150HP shot mean 150HWHP?
    By My94ZZZ in forum Nitrous
    Last Post: 03-13-2009, 08:56 PM
  4. Replies: 18
    Last Post: 07-26-2007, 06:39 PM
  5. NX 20920 New GM EFI nitrous kit Ohio 35-150HP
    By LEW2 in forum Parts For Sale / Trade
    Last Post: 02-14-2007, 11:02 AM
