Results 1 to 20 of 23
    Member JAX04's Avatar
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    2004 Pontiac GTO PBM A4
    Brake Clamping force, need more, lots more!
    When im sitting their trying to stall up, i continuously push through my brakes.
    Rear ones wont hold without spinning and if they are nice and hot, itll push through the fronts.
    I have a 3200 stall and start pushing through around 1800rpm.
    What can i do improve the clamping force to hold me still. I have, just messing around, pulled the parking brake handle up and held it up while doing this and am then able to stall to around 22-2300 rpm which according to Yank is where it should be going.
    So, what can i do to improve my clamping force of the brakes. I dont think using the parking brake is the right way to do this, i only did it as a test.
    Im basically stock for brakes with the only improvement being c5 pads in the front.
    Thanks,
    Kyle
    Apr 2011
    toronto canada
    nothing yet
    Braking
    Hi There, you should probably invest the $200 in a line lock. This will apply the front brakes only and let the rears spin freely. As for why the e-brake helped keep you planted makes me wonder. I always thought the e-brake was a mechanical cable that acted on the rears only.... but I guess I was wrong?
    Good luck.
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    It only acts on the rear. I was saying That it stops the back wheels from turning. Lol
    Sent from my Droid using Tapatalk
    I was trying to brake boost, IE- foot on brake and foot on gas, trying to stall up, i kept pushing through the brakes, the back ones couldnt hold the wheels form spinning, i pulled up the parking brake, TO hold the back wheels from spinning.
    2004 GTO,A4 turbo build in the progress and corn juice to follow
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    So nobody has any ideas?
    Member 88gtman's Avatar
    Mar 2011
    Pensacola
    Upgrade your calipers to some that have more pistons and find some grippier pads for the front.
    mercersburg pa
    hugger orange
    2004
    Look up ( 04 Gto big brake kits) on ebay, there are a number of nice peices all the way up to 16" rotor, not cheap ( I think some were around $5,000) but very nice kits.... how much do you want to pay to play? Lol. You should come up and drive my goat some time. With the manual brakes and steering it can be s handful if your not used to it
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    Those kind of things dont bother me, the problem is when im literally standing my 235LB ass on my brake pedal i can still push through the brakes,
    Its pathetic that we got such piece of shit brakes on these heavy ass cars,
    SO basically, unless i go to a better brake caliper and rotor setup, im fucked? is that what we are saying? or is their a way to LOCK the rear brakes, or simply adjust them so that they can clamp harder??
    Universal Pisser Offer Fester801's Avatar
    Oct 2009
    Grapevine, TX
    Torrid Red
    05 GTO M6
    Quote Originally Posted by JAX04 View Post
    Not sure what trans you are using, but if you are needing help with your launch and not just doing burnouts, you might put in a call to B&M and inquire about a trans brake. Their units run around 300 bucks I think. This will fix your problem and prevent you from destroying your brake system.
    Oct 2009
    Grapevine, TX
    Torrid Red
    05 GTO M6
    3200 is a ton of stall. With that much rpm your probably going to push through any brake system you put on there. You're probably going to have to Google "trans brake" and see if they make one for your application. If you're running the electronic trans, I would think this would be easy to do. If not, there are a lot of companies making brakes which are really affordable. Hope this helps.
    Oct 2009
    Grapevine, TX
    Torrid Red
    05 GTO M6
    bignikk had a good idea with the line lock. However, those are mostly used to for manual cars to hold them still on the line so you can manipulate your clutch. Even if it would hold at full pressure, you're still going to push through and ruin your brake system.
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    3200 is alot of stall?? tell the guys rocking 3600 and 4k stalls that.
    Transbrake on our rear ends is suicide. not gonna happen.
    and their is honestly no reason why i shouldn't be able to stall to around 2200 on the foot brake.
    I have a yank converter, and they have told me more then once on a foot brake you should be able to stall up 1000rpm less then the rated stall speed.
    im lucky to hit 1800 before i blow the tires off or if they are hot,ill just push right through the fronts.
    Aug 2010
    Connectitcut
    2004 gto
    try looking on ebay for factory brakes off the 06, there supposed to be bigger. not sure exactly how much better they are but i know for a fact you can get the calipers for about 250
    mercersburg pa
    hugger orange
    2004
    Behind my 408 I have a 4,000 rpm stall that flashes at about 4,500 rpms
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    I know all these things. Thank You. No traction control or tq management or anything of the like. Nothing weird other Then the fact it wont hold. Thanks.
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    Unfortunately gtos are not known for for good brakes. It just sucks.
    Mark- how far can u stall up on the foot brake?
    mercersburg pa
    hugger orange
    2004
    blew a tranny line, dumped a bunch of fluid down on the passenger side header and caught fire before I had time do much playing....got all the wiring fixed, just need to put the new shift cable and afew other things in....Shannon sent me a text here about ten minutes ago saying my new ecu came in the mail today ( old one fried during the fire) so I hope to start the car again by the end of the night
    Oct 2009
    Grapevine, TX
    Torrid Red
    05 GTO M6
    Well then, I followed your build over the last several months and was patiently waiting for results of your "TurboGoat"... If a Trans brake is not an option, then allow me to introduce you to Mr Willwood, Mr Baer, and Mr anything bigger than 04 Goat brakes. Good Luck Buddy...
    mercersburg pa
    hugger orange
    2004
    You would need atleast 19" wheels or bigger. But these are NICE.
    http://cgi.ebay.com/ebaymotors/04-06...item27b2ce229b
    Mar 2009
    indianapolis
    PBM 366ci TC78 E85
    i dont think i could ever bring myself to pay that kind of money for brakes, lol.
    Im actually looking at the camaro conversion that people are doing. or the ctsv conversion.
    Aug 2010
    Connectitcut
    2004 gto
    really? how much does somthing like that cost? also if you go that rout mind keeping us posted on that? somthing i might be interested in
  1. ..the OWS Air Force?...
    Last Post: 01-11-2012, 10:36 AM
  2. Lots and Lots of Drag .... Racing I mean
    By Faught in forum Multimedia Section
    Last Post: 07-17-2011, 10:47 AM
  3. Corvette Brake Rotors - Give Me A Brake
    By Ed Blown Vert in forum Corvette
    Last Post: 09-17-2010, 04:39 PM
  4. I love Spring... Lots and Lots of Boobies!!!
    By 98-LS1 in forum Almost Anything Goes
    Last Post: 05-08-2007, 10:15 AM
  5. BFG g-force T/A KDW-2
    By amstall in forum Wheels and Tires
    Last Post: 06-19-2006, 09:04 AM
