Results 1 to 20 of 53
04-19-2011, 12:37 PM #1
74,000 miles 2001 z28, stick, 1 owner
[IMG](img)http://1140photobucket.com[/IMG]dicksidulous/image0461.jpg(/img0[/IMG]How could at this low mileage already have a slight engine pan gasket seepage?
Bolts aint loose!
I mean aren't these engines built good?
Thought ls-1 engines are the best?
Is a smal amount a seepage at thi mileage normal?
I,m monitoring now exactly how much usage may occur between oil changes!
If any of you got any thoughts on this id apreciate hearing it.
i felt 74,000 miles is like new?
thanxLast edited by denegrader; 04-22-2011 at 01:10 PM.
04-19-2011, 12:44 PM #2
04-19-2011, 01:11 PM #3
- Mar 2007
- Henryetta/Tulsa Oklahoma
Can you visibly see a leak from the oil pan. If not, IMO you are more than likely...
a.) getting fluid collecting at the bottom from a leak somewhere else, and maybe not even oil [power steering fluid in my case]
b.) someone did a messy oil change, and the wind spread all the old oil about the oil pan.
c.) gonna have to clean it and observe more closely, as well as oil levels.
04-19-2011, 01:56 PM #4
^^^+1
Could also be the R&P leaking like mine. It can pool on the K member and while you drive it sprays the whole oil pan making it look like it's leaking from there. A good cleaning can help you try to locate it.
04-20-2011, 09:04 AM #5
R @ P ??
Well a mech said it 's the oil pan and the timing cover yeah i'm thinkin just to make a ton a money off of labor from me .
well i jacked it up wiped it and i tightened the pan bolts actualy they werent looose , and he the mech actualy had already changed the valve cover gaskets supposedly, well their blue and look new and maybe thats what was leaking and its just reside still dropping .
ill have to jack it wipe it monitor it.
i also added 1 qt of oil maybe used 1/2 qt in 250 miles.
just 5 small drops will show after it sits 15 minutes.
ill be monitoring,
wats normal useage for these??
and well ill monitor it.
04-20-2011, 09:40 AM #6
- Mar 2007
1/2 a quart in 250 miles???? I usually don't have to do anything for AT LEAST 1000, usually 2000. And my car has 203k miles. Either your estimation is off, or you really do have a problem somewhere...
04-20-2011, 11:14 AM #7
- Apr 2009
- Pennsylvania
Pewter- 2000 Camaro SS
My car sit over the winter and when i pulled it out of the garage i seen a 1 inch diameter oil spot. I have not had time to check it out but when i do i will post it here. Good luck
04-20-2011, 09:41 PM #8
one major leak source is the oil pressure sending unit (OPSU), which is at the back of the engine.. i just had a bunch of crap replaced on mine (valve cover gaskets, OPSU, rear main seal, intake gaskets, valley cover gaskets, PCV all new), ..i'll be damned if it's still dripping down from somewhere.
04-20-2011, 11:52 PM #9
well this clown mech's saying its a pan gasket and a timing cover gasket, not sure as i dont know these cars and they got to be hardest car to work on, i used to do my own work on my 5.0 but these, wat is it cause their aluminum? cause there loaded with more crap in the engine bay?
maybe cause the engines under the front widshield? maybe cause the cats are squeezed between the frame and engine? maybe cause it so low and hard to jack up and get under there.
04-20-2011, 11:54 PM #10
04-20-2011, 11:58 PM #11
its what i get for buying something i dont know about and from a stranger craigslist
04-21-2011, 07:35 AM #12
04-21-2011, 07:40 AM #13
R&P = rack and pinon. That oil consumption is way too high
And some "mechanics*" will tell you anything to get your money.
* - I quoted mechanics because there are some really bad ones out there that claim to be one and really have no business handling a wrench let alone working on a car. Not all are bad or crooked. no offense meant towards the honest ppl
Could you take a pic of underneath and your engine bay where you see the leaks? It will help a lot!!Last edited by SMWS6TA; 04-21-2011 at 08:06 AM.
04-21-2011, 08:01 AM #14
Not saying this post will fix your problems but it is to answer your questions about the OPSU and also give other areas that could be what your having problems with.
The OPSU is the tall plastic piece that is sticking up with the green cap.
These can get brittle and break over time. Also when you are messing with the intake most first timers break it because they don't know it's there. These can leak quite a bit of oil. Signs of this are oil coming down the backside of the engine over the bell housing. It is commonly mistaken for a rear main seal leak.
Another area that can cause oil/vacuum leaks is the PCV. IMHO GM screwed the pooch (<us) by using this is a POS PCV system. And on top of it over price ($85-$140 depending on where you get it) for when you need to replace it. This runs from the rear of the drivers side valve cover behind the intake where it splits, one tube goes to the passenger valve cover the other comes along the passenger side of the intake into the PCV valve then into your intake. In the pics below you can see where it cracks and leaks.
or you can do this
LS6 VCT (Valley Cover tray mod) with a catch can. Some like it some don't. This is not a performance mod buy it does help get the oil out of the intake. It deletes the PCV tubing and puts the PCV under the VCT and moves the outlet port to the front of the engine underneath the TB. This mod cost about $58-$75 for the VCT. The catch can goes for $50-$220 depending on what you want.
catch can
04-21-2011, 08:35 AM #15
- Feb 2006
- MD
04-21-2011, 10:34 AM #16
04-21-2011, 10:39 AM #17
alright thanx for the great pics and help
i took pics and ill try to put em on somehow aint did that yet.
it looks like front of pan and timing cover are dry and tranny is not wet and maybe this leak that i thought was so big may actualy be just a little seepage from the expansion of the all aluminum ls-1 engine
i saw the pcv hidden there and could not even see the o.p.s.u.
w/the few drops and small wetness on the bottom left side of pan just a 4 inch 1 inch wide small patch
04-21-2011, 10:48 AM #18
aint starting a ford versus chevy thing here fact is i have used 1 qt of oil was every 800 miles now its about 1qt every 400 miles leaked outta valve cover gaskets tightened em in 1/2 hour no more leaks there in the 5.0 since 107,000 miles
both got positives and negatives well with 240,000 miles on the 5.0 now engine never had heads opened still runs like a bat outta hell all stock.still daily driver was till recent ly purchased this z
to me beuatiful car the z hard to work ,on compared to the 5.0
z great handling, give something get something, oh 5.0 hard to say where oil is cause not much on ground always passed smog still moves anyways,
the leak on the z doesnt seem as bad as i first thought.
04-21-2011, 10:51 AM #19
04-21-2011, 10:52 AM #20
For Sale: 2001 Camaro SS #4842 one owner 28,xxx miles - St. Louis area
By hammertime in forum Vehicles For Sale / TradeReplies: 5Last Post: 07-11-2014, 06:14 AM -
New 2001 WS6 TA owner in Pembroke Pines, FL
By fjm1235 in forum New Member IntroductionsReplies: 3Last Post: 10-09-2011, 10:43 AM -
For Sale: 1999 z28 one owner 94,000 miles
By jerrybluesky in forum Vehicles For Sale / TradeReplies: 3Last Post: 05-23-2009, 06:19 PM -
FS: 02' Stripper Z28 M6 with 9,000 miles one owner
By OBSSSD in forum Vehicles For Sale / TradeReplies: 9Last Post: 09-20-2008, 07:15 AM -
Proud new 2001 SS owner
By eymana in forum New Member IntroductionsReplies: 6Last Post: 06-04-2008, 03:35 PM
